Finding the Relationship Between -sin 40 & -cos 50
  • Thread starter Thread starter lLovePhysics
    Relationship
The discussion revolves around understanding trigonometric identities and simplifying algebraic expressions. The relationship between -sin 40 degrees and -cos 50 degrees is clarified through cofunction identities, specifically that sin(θ) = cos(90° - θ). Participants also explore algebraic simplification, questioning whether it is valid to multiply expressions by -1 to facilitate cancellation in fractions. The importance of maintaining the value of expressions during manipulation is emphasized, particularly when canceling terms. Additionally, a brief inquiry into the definition and calculation of standard deviation is made, with a correct method for finding it provided.
lLovePhysics
I know that sin 320 deg is equal to -sin 40 deg. However, how do you know that -sin 40 deg is equal to - cos 50 deg? Thanks
Hmm... I think it is something about cofunctions. I'm going to read more into it first. =]
You know because of the cofunction identities:
\sin{\theta} = \cos{(90-\theta)}
\cos{\theta} = \sin{(90-\theta)}
\tan{\theta} = \cot{(90-\theta)}
\cot{\theta} = \tan{(90-\theta)}
\sec{\theta} = \csc{(90-\theta)}
\csc{\theta} = \sec{(90-\theta)}
Draw a right triangle and look at the relationships.
Ok thanks.
Also, how do you solve this problem?:
\frac{x^{2}-9x+14}{3x^{3}-6x^{4}} \times \frac{2x-1}{x^{2}-2x-35}
I simplified it down to:
\frac{(x-7)(x-2)}{3x^{3}(-2x+1)} \times \frac{2x-1}{(x-7)(x+5)}
Is there a way to cancel out (-2x+1) and 2x-1? Is it okay to multiply (-2x+1) by -1 or is it wrong because it changes the value? When I set them equal to one another they cancel out to equal 0. Why is this?
Thanks.
lLovePhysics said:
Ok thanks.
Thanks.
Don't set them equal... you can do a number of things... you can multiply the numerator and denominator by -1... that keeps the fraction the same, and let's you multiply out the (-2x+1) by -1...
Or multiply the denominator by (-1)*(-1) which is just one so you're keeping the value of the fraction the same... but you can use one of the -1 to multiply (-2x+1) by -1...
The essential idea is that -2x+1 = -1*(2x-1) = -(2x-1). You can also think of it as factoring out the -1.
Remember that whatever operations you do, you don't want to change the value of the quantity you're evaluating...
When you cancel things out with multiplication, you're dividing something by itself... so you don't get 0, but 1...
Thanks for your reply! I didn't even see that you could factor -1 out. Does anyone know the correct definition of Standard Deviation and how to find it? I've searched on google and all that came up were some confusing equations...
Yes, u have to use those confusing equations to calculate standard deviation.
http://www.answers.com/topic/standard-deviation?cat=biz-fin#
I liked the one that's in "Accounting Dictionary" section(scroll down to there), and
if you further scroll down, wikipedia explains it all (including that bell curve)
Okay, I'm nowhere near that level of math so I've found a defintion that I think I can apply. Please tell me if you think this is accurate or not:
"The standard deviation is a measure of spread- how far the observations in a set of data are from their mean."
Here's a problem of standard deviation:
Of the following lists of numbers, which has the smallest standard deviation?
a) 1, 5, 9
b) 3, 5, 8
c) 4, 5 ,8
d)7, 8 , 9
3) 8, 8, 8
So would you calculate all of their means for example (7, 8, 9): (7+8+9)/3=8 and then see how far the data {7,8,9} are from that mean?
In this case 8,8,8 has a mean of 8 which is the smallest out of all of them. Does that seem like the correct way to do it? Thanks
Theres a certain method to calculate the standard deviation.
First find the mean of each of those sets. Now Find the difference between each of the scores and the mean. Square each of them. Sum that, and divide that by the number of scores. Now square root the whole thing. That gives the Standard Deviation.
