What is the solution to this trigonometric limit question?
The limit of (1 - cosX)/X^2 as X approaches 0 can be evaluated using the identity sin^2(X) = (1 - cosX)(1 + cosX). By multiplying the numerator and denominator by (1 + cos(X)), the expression simplifies to sin^2(X)/(X^2(1 + cos(X))). As X approaches 0, the limit of sin(X)/X equals 1, leading to the conclusion that the limit is 1/(1 + cos(0)), which equals 1/2. This approach effectively resolves the limit question posed.
shocker121
Lim (1-cosX)/X^2
X->0
Not 100% sure try to use the following identity:
sin^2(X)=(1-cosX)(1+cosX) or
sin^2(X)=1-cos^2(X)
Tried substituting (sin^2(X))/(1+cosX)) for 1-cosX but that didnt help and so for the last half hour I've been staring at this problem and I am still lost. Somebody help me out.
Possible answers were 0, .5, 1, 2
shocker121 said:
Lim (1-cosX)/X^2
X->0
sin^2(X)=1-cos^2(X)
There are at least a couple of ways to do this, but one of them might not be applicable based on which class you're in.
Try multiplying the numerator and denominator by (1 + cos(x))/(1 + cos(x)). Then make your substitution. If you do that, the limit, as x --> 0, will be
lim \frac{sin^2(x)}{x^2(1 + cos(x))}
Now, do you know any limits that involve sin(x) and x, as x --> 0?
Im in AP calculus B/C if it affects your answer at all
and if I'm not mistaken
limit sin(x)/x = 1
x-> 0
and
limit sin^2(x)/x^2 = 1
x-> 0
but how would i go about seperating the the 1+cos(x) from the denominator
could i make the function
limit (sin^2(x)/x^2)*(1/(1+cosx))
x-> 0
then substitute in for x?
limit sin(x)/x = 1
x-> 0
and
x-> 0
x-> 0
Not quite, but a property of limits is that lim (A * B) = lim A * lim B, providing that all the limits exist. Is that enough of a hint?
The other approach is to look at the infinite series for 1 - cos(x). I hesitated to point you in that direction since I didn't know where you were in your course. If you're interested in the details of this approach, let me know.
Mark
Yes, you certainly can write
\frac{1- cos(x)}{x^2}= \frac{(1- cos(x))(1+ cos(x))}{x^2(1+ cos(x))}
= \frac{1-cos^2(x)}{x^2(1+ cos(x))}= \frac{sin^2(x)}{x^2(1+ cos(x))}
= \left(\frac{sin(x)}{x}\right)^2 \frac{1}{1+ cos(x)}
That should make the limit easy.
