MHB Optimizing Resultant Forces: Finding Maximum and Minimum Magnitudes
The discussion focuses on determining the maximum and minimum magnitudes of the resultant force from three horizontal forces of 8N, 15N, and 20N. The maximum resultant occurs when all forces are aligned in the same direction, while the minimum can be achieved by positioning two forces in one direction and the third in the opposite direction. A key insight is that a zero magnitude resultant can be obtained by arranging the forces to form a closed triangle. The use of head-to-tail vector addition is emphasized for visualizing these arrangements. Overall, the problem illustrates the importance of vector orientation in calculating resultant forces.
Needhelp2
Three horizontal forces of magnitudes 8N, 15N and 20N act at a point. The 8N and 15N are at right angles to each other. The force 20N makes an angle of 150 degrees with the the 8N force and an angle of 120 degrees with the 15N force.
State the greatest and least possible magnitudes of the resultant force if the directions of the three horizontal forces can be altered.
Any help would be greatly appreciated, the question had many parts, the last one ( the one above) threw me (Nerd)
Thank you!
sorry for the poor diagram!
Mathematics news on Phys.org
I believe that the greatest magnitude will be when they all have the same direction and the minimum magnitude will be when two are in one direction and the third is in the opposite. This can be demonstrated visually by head to tail addition. I know this is true for two vectors and I don't see why it shouldn't apply to three.
[EDIT] This post is completely wrong, as shown by Opalg's post below. Please disregard.
You can actually get a zero magnitude resultant vector in a fairly straightforward manner, at least in this problem. Solution: put the 20N force going straight left, and the 15N force going straight right. Then put the 8N force at an angle such that its x-component is +5. You can use the inverse cosine function to find out what angle that will be (there are actually two solutions, of course). Since you can't get a negative magnitude for the resultant vector, this will be the minimum.
To get the forces in equilibrium (so that the resultant force has zero magnitude), arrange their directions so as to form a closed triangle, as in the diagram.
Thank you so much! It came up in my Mechanics mock, so the fact I couldn't do it worried me slightly... But the simple solution makes me feel a bit better :)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
