Triple Integral for Cylindrical Coordinates in a Parabolic Region
robbondo
Find the triple integrals \oint\oint\oint_{W}{f(x,y,z)dV:
e^{x^{2}+y^{2}+z}, (x^{2}+y^{2}) \leq z \leq {(x^{2}+y^{2}})^{1/2}
So I know I need to probably switch to cylindrical coordinates. But I'm getting confused about the limits of integration. The way that I see it, since there's no limits of integration for z then the volume which is the between the two parabolas goes to infiniti? But since it's the same above and below the z=0 plane then doesn't that just come out to zero? I don't know I guess if I do the integral from x going from -infiniti to infiniti and use an improper integral from some (a = infiniti) with the limits of integration for z being then from a to a which is obviously zero. I don't think that he would make up a problem like that though. Am I completely wrong in my thinking. THANKS!
You do NOT have two paraboloids- and none of the figure is below the z= 0 plane. z= x^2+ y^2 is a paraboloid with vertex at (0,0,0), axis the z-axis, and opening upward. z= (x^2+ y^2)^{1/2} is the upper half of the cone z^2= x^2+ y^2[/itex]. It does not go to infinity. The two surfaces intersect at z= x^2+ y^2= (x^2+ y^2)^{1/2}. Putting that into cylindrical coordinates makes it particularly easy: z= r^2 and z= r interxect when r^2= r.
Ok So know when I try to do the integration am I correct to use the limits of integration of that z goes from 0 to 1 and theta goes from 0 to 2pi and then r goes from root z to z? Also I tried using z from r to r^2 r from 0 to 1 and theta from 0 to 2pi, and they are all giving me strange integrals. Are these limits correct? I'm having a hard time figuring out how to change the limits of integration when switching to cylindrical, especially with regards to r.
I'm still having trouble figuring out the limits of integration on this one. Every way that I do it I keep having to take the integral of
x*e^(x^2+x) which as far as I know isn't possible to do. I tried plugging it into a numerical solver and it gave me an exact answer that looked like some sort of estimation. HELP! I have a mid-term Tues. and this determing the limits of integration is going to screw me big time.
I'm beginning to think that my teacher made an error in writing this problem. It appears to be unsolvable through all my efforts.
No, z does NOT go from 0 to 1. The whole point of what you are doing is that z goes from the lower of those two surfaces (z= x2+ y2) to the higher surface (z= \sqrt{x^2+ y^2}). Since I have already told you that the two surfaces intersect where r2= r- which tells you r= 0 or r= 1, projected down into the z= 0 plane, the two surfaces project the the area from (0,0) to the circle about (0,0) with radius 1. That is, \theta goes from 0 to 2\pi while r goes from 0 to 1.
\int_{\theta= 0}^{2\pi} \int_{r=0}^1 \int_{z=r^2}^r e^{r^2+ z} rdzdrd\theta[/itex]<br /> I <b>think</b> that&#039;s the integral you need to do. You never <b>did</b> say that f(x,y,z)= e^{x^2+y^2+ z}.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
