Trouble finding F(x) for a particle moving on a horizontal plane
A particle of mass m moves on a frictionless horizontal plane with speed v(x) = k/x. The force acting on the particle is derived from the acceleration, leading to the expression F(x) = -mvk/x^2. Upon substituting v with k/x, the final force function is simplified to F(x) = -mk^2/x^3. Participants in the discussion confirm the correctness of the calculations and share tips on handling calculus concepts. The conversation highlights the importance of expressing force as a function of position.
astenroo
A particle of mass m moves along a frictionless, horizontal plane with a speed given by v(x)=k/x, where x is its distance from the origin and k is a positive constant. Find the force F(x) to which the particle is subject.
F(x)=m\ddot{x}
\ddot{x}=\frac{d\dot{x}}{dt}=\frac{dx}{dt} \frac{d\dot{x}}{dx}=v\frac{dv}{dx}
So i figured, if i differentiate v(x)=k/x I end up with v'(x)=-k/x^2, so F(x)= m\ddot{x} and if I substitute my expression for \ddot{x} I end up with F(x)=-mvk/x^2. Why do I get the feeling I'm all wrong about this one?
hi astenroo! :smile:
astenroo said:
… I end up with F(x)=-mvk/x^2. Why do I get the feeling I'm all wrong about this one?
dunno :confused:
looks ok … now get rid of the v, to make F a function of x :smile:
Remember that v = k/x. Plug that back into your expression for F(x).
Heh, I actually suck at calculus, so when I end up with a fairly straight forward solution, I get the feeling I've done something wrong :) Calculus cannot be simple :D
So, my first attempt was F(x)=-mvk/x^2, and if v(x)=k/x then F(x)=-mk^2/x^3.
Thanks for the hints.
btw, note that vdv/dx can also be written d/dx (1/2 v2) :wink:
Heh, so true. Thank you :)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
