How Do Sinusoidal Waves Affect String Motion?
  • Thread starter Thread starter tj.
    Sinusoidal Waves
The discussion focuses on the effects of sinusoidal waves on string motion, specifically addressing a homework problem involving wave frequency, amplitude, and wavelength. Part a) was solved correctly, determining that it takes 0.372 seconds for the wave to travel 8.50m. However, part b) remains unclear, with confusion surrounding the correct equations to use for calculating the transverse distance a point on the string travels. The moderator suggests first calculating the distance traveled in one oscillation, which is linked to the wave's amplitude. The conversation emphasizes understanding the relationship between wave properties and string motion for accurate problem-solving.
tj.
A continuous succession of sinusoidal wave pulses are produced at one end of a very long string and travel along the length of the string. The wave has frequency 36.0Hz, amplitude 5.50mm, and wavelength 0.635m.
a) How long does it take the wave to travel a distance of 8.50m along the length of the string?
b) How long does it take a point on the string to travel a total accumulated transverse distance of 8.50m, once the wave train has reached the point and set it into motion?
So I've been able to do part a) with ease but the trouble I'm having is with part b). It just completely confuses me!
Do I need to use the equation y(x,t) = Acos(kx - \omega t) or \frac{\partial^{2}y(x,t)}{\partial x ^{2}} = \frac{1}{v^{2}} \frac{\partial ^{2}y(x,t)}{\partial t^{2}} or v_{y}(x,t) = \omega Asin(kx - \omega t) or something different??
So for part a) I got t=0.372 seconds using v=f\lambda and b) is an unknown to me.
Thanks in advance if anyone can help!
First find how much distance the point travels in one oscillation, then find how many oscillations correspond to 8.50 m.
So I got the exact same answer as part a). Would that be correct??
Moderator's note: thread moved to Introductory Physics, as this appears to be college sophomore level physics.
Uh, no. First answer this: how much transverse distance does the point travel in one oscillation? Hint: it is related to the amplitude.
(Back to you, kuruman ... :smile:)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
