Troublesome coefficient of variation question
To calculate the coefficient of variation (COV) for investments A, B, and C, the correct formula is the standard deviation divided by the expected profit, resulting in A: 0.1, B: 0.25, and C: 0.14. Investment A has the lowest COV, indicating it is the least risky option. A diagram illustrating the normal distribution of profits can help visualize the range of expected profits for each investment. Approximately 69% of the values fall within one standard deviation of the mean, providing a clearer understanding of risk levels. This statistical approach aids in comparing the relative risks of the investments effectively.
th_05
Given the following data for three possibile investments, A, B and C, calculate the coefficient of variation and with the aid of a diagram explain which is the least risky investment.
Expected Profit: A - 100 B - 120 C - 140
Standard Devi.: A - 10 B - 30 C - 20
I presume to calculate the COV you divide the standard deviation by the mean, to give you:
A: 100/10 = 0.1 B: 30/120 = 0.25 C: 20/140 = 0.14
I am struggling with how/what sort of diagram to use and how to explain which is the least risky investment. Any ideas would be great.
In your first calculation for COV, you have 100/10 and you should probably have 10/100.
Neither of the statistics books I have has a definition for coefficient of variation, so that's a new one on me.
Something that might be helpful is that in a normal distribution, about 69% of the values fall within one standard deviation of the mean. If the profits in these investments are normally distributed, then for investment A, we would expect that 69% of the time the profit would be between $90 and $110. If you look at each of the other investments in a similar manner you'll get a range of possible profits for each, so maybe you can determine the relative risk in this way.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
