True False-two long current carrying wires?
  • Thread starter Thread starter sona1177
    Current Wires
The discussion revolves around the forces between two parallel current-carrying wires, focusing on the validity of various statements regarding their interactions. It is clarified that if the current in wire A increases, the force on wire B will indeed increase, but the force on wire A remains unchanged. The forces between the wires increase when they are brought closer together, and they attract each other when currents flow in the same direction. However, if the current in wire A goes to zero, both wires will not feel a force, contradicting the notion that wire B would still experience a force. Overall, the participants are seeking clarity on the correct interpretations of these principles.
sona1177
Consider two long current-carrying wires (A and B) that are parallel to each other. Which of the following statements are true about the force between these two wires?
if the current in wire A increases, then the force on wire A will stay the same, but the force on wire B will increase
if the wires are brought closer together, the force between them will increase
if the currents are in the same direction, then the wires will attract each other
if the current goes to zero in wire A, then wire B will still feel a force, but wire A will not feel a force
if the currents are in opposite directions, then the wires will attract each other
if the current goes to zero in wire A, both wires will no longer feel a force
answers:
false
true
true
false
false
false
I can't really figure out what is wrong. can someone please help?
Hi Sona.
the first statement is true. force on each wire is equal in magnitude and opposite in direction. it is a mutually felt force.
the last statement is true, for same reason as above.
