Try to plot it on mathematica for x=200
In summary, the conversation revolves around proving the limit of a mathematical expression and understanding the concept of an analytic function. There are various approaches to proving the limit, including using Stirling's approximation and analyzing the rate of increase. It is also mentioned that L'Hospital's rule is not applicable in all cases. To understand the concept of an analytic function, one can use analogies or graphical explanations. The conversation also briefly touches on the use of Taylor series and the Wallis formula in proving Stirling's approximation.
steven187
176
hello all
how would one prove that [tex]\lim_{n\rightarrow\infty}\frac{x^{n+1}}{(n+1)!}=0[/tex] [tex]\forall x\in\Re [/tex] now when i try to plot it on mathematica for x=200, on the plot it displays that [tex]200^{n+1}>(n+1)![/tex] how could it possibly converge for any value of x? the reason why i need to prove this is because I am trying to show that a function is analytic, would somebody have an anology or a graphical explanation of what is meant by an analytic function?
Steven
You could use Stirlings approximation to the factorial, but that's not necessary. Here's a brutal approach. First if 0<=x<=1 the result is obvious, so assume x>1. Fix x, let N be any integer larger than x^2. Then [tex](N+M)!>(N)(N+1)\ldots(N+M)>N^M>(x^2)^M[/tex] for any positive integer M. Hence:
[tex]\frac{x^{N+M}}{(N+M)!}<\frac{x^{N+M}}{x^{2M}}=x^{N-M}[/tex]
Thinking of n+1=N+M, your limit is now the limit as M->infinity and hence is zero.
If x is negative, the result will still hold, multiplying the terms by +/-1 the limit will still be zero.
stirling is vast overkill. this obviously converges to 0, for any x. just notice that after n is larger than x, then each term is obtained by multiplying the previous one by something smaller than x/n, which is less than 1.
i.e. in each successive term the top is multiplied by the same old constant (x), but the bottom is multiplied by something getting larger and larger.
as soon as the bottom catches up to the top, the eventual future is clear.
Overkill-yes, I only mentioned it because of some his other posts and he'll be meeting stirling's if he carries on studying zeta.
I also had meant to mention the attempt to graph this in mathematica when x=200. You probably weren't able to look very far. This will only start to turn around and decrease at n=199, where it has over 80 digits. I don't know mathematicas limits, but this is likely a problem (this is a good warning to beware any finite amount of data when dealing with an infinite limit). Try ploting log of this function if you want to look furthur.
now what I want to conclude is that for large values of n,
[tex]n<n^2<e^n<n!<n^n[/tex]
so would it be true to say that
[tex]\lim_{n\rightarrow\infty}\frac{n!}{n^n}=0[/tex]
what i realize is that it all depends upon how fast each increases as n goes to infinity, the reason why i want to make such a conclusion is so that next time i come across a limite i will know weither the numerator is less than the denominator as n goes to infinity so that i will be able to know the limite of by heart, is there any special way of proving such limits, would L' hospital rule be the most general method to do such limits? well i will be reseaching into stirlings hopefully pretty soon is there any prior knowledge i need to know before i start on it?
Yes.
Thats perfectly correct and its a good way to make the analysis IMHO. However ofcourse not all limits can be gauged in this manner. There may be some limits where numerator and denominator, either proceed at the same rate or we don't see an immediate way to compare their rates. (simple example being those functions which are not monotonically increasing or decreasing)
Not such a good idea. Its better to do analysis each time you find a limit. Nonetheless, even if you don't byheart, by enough practice you can evaluate limits in under a minute (given its moderately hard).
Special way to do all limits? nope. You can use taylor series, and you can use your idea of rate of increase and some more stuff.
L'Hospital is the cut down version of taylor series method, so you can easily say its not applicable where you cannot use taylor series.
Stirling's formula is an approximation for factorial and nothing else. However, if u want to understand the proof of it then for the method i recall, you need
simple algebra,
integration and
taylor series for log
Along with it you need to use the (not-so) famous wallis formula. The proof of which again is simple. Both of these proofs are available on net, a simple google search should lead you to them.
-- AI
steven187 said:
hello all
Steven
im trying to draw a picture in my head so i could refer to it when needed
thanxs
1. What is Mathematica and how can I use it to plot a function?
Mathematica is a powerful software program used for mathematical and scientific computations. It allows users to input mathematical functions and equations and then visualize them through graphs and plots. To plot a function in Mathematica, you can use the "Plot" function and specify the desired range of values for the independent variable.
2. Can I plot multiple functions on the same graph in Mathematica?
Yes, you can plot multiple functions on the same graph in Mathematica by using the "Plot" function for each function and then using the "Show" function to combine them into one graph. You can also use the "Plot" function with a list of functions as the first argument to plot them all at once.
3. How do I customize the appearance of a plot in Mathematica?
There are several ways to customize the appearance of a plot in Mathematica. You can use various options within the "Plot" function, such as changing the color, style, and thickness of the lines. You can also use the "AxesLabel" option to add labels for the axes and the "PlotLabel" option to add a title for the plot. Additionally, you can use the "PlotRange" option to specify the range of values for the axes.
4. Can I save my plot in Mathematica as an image or in a different file format?
Yes, you can save your plot in Mathematica as an image or in a different file format by using the "Export" function. This allows you to save the plot as a JPEG, PNG, PDF, or other image or document file format. You can also use the "Save" function to save your entire Mathematica notebook, including the plot, as a .nb file.
5. Is it possible to animate a plot in Mathematica?
Yes, it is possible to animate a plot in Mathematica by using the "Animate" function. This allows you to specify a range of values for the independent variable and see how the plot changes as the variable varies. You can also use the "Manipulate" function to create interactive plots where you can change the values of certain parameters and see the corresponding changes in the plot.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
  • MATLAB, Maple, Mathematica, LaTeX
