Trying to figure out gravitational attraction between two objects.
The discussion focuses on calculating the gravitational attraction between two objects using Newton's Law of Universal Gravity. The formula used is F = G * (M1 * M2) / R², where G is the gravitational constant (6.673 x 10-11 N m2 kg-2), M1 and M2 are the masses (400 kg and 300 kg respectively), and R is the distance (2000 m). Participants clarify that F1 and F2 represent equal forces exerted by the two masses, and the resulting gravitational force is extremely small, approximately 0.0000000000667 when calculated correctly.
  • Understanding of Newton's Law of Universal Gravity
  • Basic knowledge of mass and distance units (kilograms and meters)
  • Familiarity with exponents and scientific notation
  • Ability to perform basic arithmetic operations
  • Learn how to apply Newton's Law of Universal Gravity in various scenarios
  • Explore the concept of gravitational force and its implications in physics
  • Research the significance of the gravitational constant (G) in different contexts
  • Practice using scientific calculators for physics calculations
This discussion is beneficial for students learning physics, particularly those in elementary education, as well as educators seeking to explain gravitational concepts and calculations effectively.
LuigiHomer
Trying to figure out the gravitational attraction between two objects using Newton's Law of Universal Gravity.Need to figure out what the force is.Here is a model.If anything is in ordinary parentheses then it is an exponent.
----------------------G
--------____________|_____________400x300
F1=F2=[6.673x10(-11)N m(2) kg (-2)] -----
-------------------------------------2,000(2)
Force is proportional to the product of the two masses{120,000}and inversely proportional to square of distance between two point masses.{4,000,000}
Please help me figure out what F1 is,since F1 is equal to F2.
-LH
First thing you must do is ensure all your numbers are in the right units: kilograms & metres (since those are the units that G is in). I don't know what units your numnber are in now.
F - the force between them - will be equal to your formula there.
Okay.The two point masses are in KG.The distance is in metres.G is in Newtons.
So, what answer did you get?
The formula you have listed will calculate "the force of attraction between two bodies". One force, not two. Not sure where the F1=F2= came from.
I can't figure it out.Kind of new to the concept of using Newton's laws.Kind of new to physics.
I would think F1 is force felt by object #1 and F2 is the force felt by object #2, and they are equal in magnitude, while opposite in direction.
Simply multiply and divide and you are done.
G x M1 X M2 / (R x R) = F1 = F2
From your post we have:
M1 = 400 KG
M2 = 300 KG
R = 2000 M
And we know G.
So, just do the math! There's no physics left to figure out.
I don't have a calculator that can even REGISTER Newtons,and our teacher took it away.:(What a meanie.
My sister THINKS it is 0.030.
Do you guys have a suggestion
for a good, reliable computer calculator for free that can do what Molinaro said to do?
@ DaveC,It is that they BOTH exert gravitational force.F1 is equal to F2,which is the other force.
> START > PROGRAMS > ACCESSORIES > CALCULATOR
then menu > VIEW > SCIENTIFIC
My sister didn't incorporate G.My head hurts.I'm only in 5th grade,you know.
I think it's 0.6.Please help me.More.
You don't need a calculator that registers' Newtons...
You're just doing math.
They do both exert a force. That formula will calculate the entire forfce between the two masses.
Once again,I AM A FIFTH GRADER!
I'm sorry, I missed that.
Have you learned exponents?
6.67x10^-11 is equal to .0000000000667
So:
F = (.0000000000667)*400*300 / (2000^2)
Masses of 300-400kg that a distance of 2km have an extremely small force of attraction.
Your answer should be a very, very small number - about 11 zeros.
No, we didn't know that, until you mentioned it in this post. :rolleyes:
  • · Replies 17 ·
