Trying to invert an expression
  • Thread starter Thread starter Morberticus
    Expression
The discussion revolves around inverting the expression n(k) = ∫ cos(k(x-y)) f(x,y) dxdy to obtain f(x,y). The original poster initially confused the notation and was corrected regarding the inclusion of k in the integral. A participant suggests that the transform resembles a "cosine transform" and provides a resource for further exploration. They also confirm that the inverse Fourier transform could be applicable in this context. The conversation emphasizes the importance of correctly identifying the transform type for successful inversion.
Morberticus
I've come across an expression that looks like
n(k) = ∫cos(x-y)f(x,y)dxdy
Is there a name for this transform? I would like to invert it to obtain f(x,y) but I'm not used to the 2D integral on the RHS. I tried to turn it into a Fourier transform:
n(k) = 1/2 ( ∫eixe-iyf(x,y)dxdy + ∫e-ixeiyf(x,y)dxdy)
but got stuck. Any help would be appreciated.
Thanks
Mathematics news on Phys.org
Hi, there is something of strange, where is ##k## in the integral?, you say ##n(k)## but in the right side I don't see ##k##, and what is the domain of integration ?
You are right! Sorry, I forgot about the k when writing down the expression(s). The correct expression is
n(k) = ∫ cos( k(x-y) ) f(x,y) dxdy
Thanks
I think your transform is analogous to the ''cosine transform'', I hope you can find something useful here
http://dsp-book.narod.ru/TAH/ch03.pdf
but I think (as you wrote...) it is possible to use the inverse Fourier transform...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
