Trying to understand the normalisation of the scale factor to be 1 today
The discussion centers on the normalization of the scale factor in cosmology, specifically setting it to 1 at the present time, t_0. The participants explore two methods of normalization: changing units to make t_0 = 1 and using a dimensionless scale factor defined as a(t) = (t/t_0)^{2/3}. The first method is criticized for introducing dimensional inconsistencies, while the second method is favored for maintaining a dimensionless scale factor. It is emphasized that the scale factor's definition as a ratio of proper distances at different times is crucial for avoiding confusion in density calculations. The conversation concludes with a consensus that the second normalization method is the correct approach.
Heldo Jelbar
Hello all! I'm trying to understand the standard normalisation of the scale factor to be set to 1 at today's time. Looking at the first Friedmann Equation for a spatially flat Robertson Walker metric with no cosmological constant gives
\frac{\dot{a}^2}{a^2} = \frac{8\pi G}{3}\rho
If we wanted to see how the density of the universe changed from the beginning of the matter dominated era to today, we would set
a(t) = t^{2/3}
This means that,
\frac{\dot{a}^2}{a^2} = \frac{4}{9t^2}
inserting this back into the Friedmann Equation, we get
\rho = \frac{1}{6\pi Gt^2}
So we see that in a expanding universe the density decreases as 1/t^2, which is sensible. But my question is this: if we normalise the scale factor a(t) such that a(t_0) = 1, where t_0 is today's time, then one way of doing this is to use units where t_0 = 1. This then would make a(t_0) = 1 straightforwardly for any power law expansion of scale factor. But normalising the scale factor in this way messes with the density time relation. As all times in the past have t< 1, a 1/t^2 relation will actually show that the density is INCREASING in time as the universe expands, as t is less than one before today. But this is no longer sensible.
So does anyone know how to correctly normalise the scale factor to avoid this issue? Any answers with their justifications would be great, and a reference to where I can read more about this would be even better! Many many thanks in advance!
Space news on Phys.org
What are you talking about? If the density ~ 1/t^2, the density will always be decreasing as t increases, regardless of whether t>1 or t<1.
Sorry, you're right. There was a deeper reason I was asking however. There seem to be two different ways in which the scale factor can be normalised, at least as far as I can see. Either you can:
1) Change your units of time such that t_0 = 1, and use a(t) = t^{2/3}
2) Normalise the scale factor by setting a(t) = \left(\frac{t}{t_0}\right)^{2/3}
I'm not sure which is the correct one. In the first case simply changing the units means that the scale factor has dimensions, time to the power 2/3. In the second case the scale factor is dimensionless. I think the correct answer is the second one, and I was trying to think of why the option 1) wouldn't be allowed, which made me make the mistake you pointed out. I think that the scale factor has to be dimensionless.
Does anyone know how exactly the scale factor is normalised? Is the normalisation factor as simple as in option 2), or are there more terms? Do you know where I can find out more? For instance, how is the value of t_0 calculated?
Well, I'm not saying this is the only way to do it, but I think the convention is that the scale factor is defined to be a ratio between the proper distance at time t and the proper distance at time t0. As such it is dimensionless, and the scale factor at time t0 = 1.0. It is then arbitrary what time is defined as t0, but it is usually taken as t0 = today.
Heldo Jelbar said:
So we see that in a expanding universe the density decreases as 1/t^2, which is sensible. But my question is this: if we normalise the scale factor a(t) such that a(t_0) = 1, where t_0 is today's time, then one way of doing this is to use units where t_0 = 1. This then would make a(t_0) = 1 straightforwardly for any power law expansion of scale factor. But normalising the scale factor in this way messes with the density time relation. As all times in the past have t&lt; 1, a 1/t^2 relation will actually show that the density is INCREASING in time as the universe expands, as t is less than one before today. But this is no longer sensible.
Well, setting a(t_0) = 1 is a trivial operation, because the scale factor has no units. However, setting t_0 = 1 is not a trivial operation, because t_0 has units. If you are using kilograms-meters-seconds units, for instance, performing the manipulations as you have above essentially ends up setting t_0 = 1s, not t_0=1. And arbitrarily setting the current age of the universe to one second is obviously wrong.
One simple way to take care of this would be to just put every time in the past in terms of t_0. This would be equivalent to Heldo Jelbar's second equation:
a(t) = \left({t \over t_0}\right)^{2 \over 3}
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Title: Can something exist without a cause? If the universe has a cause, what caused that cause? Post Content: Many theories suggest that everything must have a cause, but if that's true, then what caused the first cause? Does something need a cause to exist, or is it possible for existence to be uncaused? I’m exploring this from both a scientific and philosophical perspective and would love to hear insights from physics, cosmology, and philosophy. Are there any theories that explain this?
