Trying to Wire a Washing Machine Motor To Power a Grain Mill
The discussion revolves around the challenges of wiring a Whirlpool washing machine motor to power a grain mill for grinding barley. Participants explore the technical aspects of motor operation, wiring configurations, and the potential need for additional components like capacitors. The scope includes practical application and troubleshooting of electrical components.
  • One participant describes successfully starting the motor but notes it overheats quickly, suggesting a wiring issue.
  • Another participant mentions the importance of a capacitor for motor operation, indicating that the absence of one could lead to overheating.
  • There is a discussion about the motor's part number and its specifications, with a participant expressing a desire to salvage the motor despite the challenges.
  • Some participants propose examining the wiring configuration and the connections to the motor to identify potential errors.
  • A later reply questions whether the motor can operate effectively without a capacitor, highlighting differing opinions on the necessity of this component.
Participants do not reach a consensus on the necessity of a capacitor for the motor's operation, and multiple competing views regarding wiring and component requirements remain unresolved.
Limitations include the lack of detailed specifications for the motor's wiring and the potential dependence on specific configurations that may not be universally applicable.
  • #61
Ronald J Beach said:
I too want to use the low speed feature of this motor. I have two items salvaged when my a/c unit was replaced this summer. 1). TITAN HD Motor Run Capacitor, PRCFD605A, 60+5 MFD +- 5%440/370 VAC 60/50 Hz. It has HERM, FAN and C on top. 2).
You must use a Motor Run capacitor.
The one you have is really two capacitors, one for the compressor (60 MFD between the HERM terninal and common, and 5 MFD between the FAN terminal and common.)
Probably the compressor in your air conditioner is a lot bigger than this washing machine motor,.and the fan a lot smaller.
So the 60 MFD is oversized and the 5MFD is undersized.
You haven't said what it is you're powering with this motor.The washing machine used a 45 MFD capacitor , see post #43 and look up that part number (24db450b250pa)
the 60 MFD will allow excessive current and that's hard on one winding
but would be okay for a few minutes to test your motor.
The 5 MFD will allow too little current giving a really weak start . That's very hard on the other winding.. Do not let the motor hum and labor trying to start.
If the 60 MFD works,
buy yourself a 45 MFD ,
250 volts or more
motor run capacitor .
Any good electrical supply house will have it for i'd guess less than $15.
Amazon and Ebay will have them too.
Good Luck
old jim
  • #62
Jim,
Thank you for the reply and help.
You haven't said what it is you're powering with this motor. I want to use it to make a tumbler (a.k.a. rock polisher or as the pryo guys say "ball mill") like the light weight ones sold by Harbor Freight. I will have to do the math for the rpm of the container when I get the motor situation sorted out and the frame built, belt bought and the container made.
I did the ohm test as suggested by you in previous posts and also did the hum test and run test by touching wires of a cord I made up to the leads as shown in the pictures. All this checks out.
I will pursue the proper motor run capacitor.
Thanks again.
  • #63
If it's a very light rock tumbler , like the hobby ones I've seen,
that is almost no load at all for a husky washing machine motor.
You might get away with a shortcut..
Try your 5 MFD capacitor with no load on the motor, ie just bare shaft.
If you're lucky it will hum for just a second or two while starting , then accelerate and become pretty quiet as it reaches running speed. If you have a clamp-around ammeter measure current and compare to nameplate amps.
If it does start
Then try that again with your tumbler connected.
If it successfully starts the tumbler with 5 MFD capacitor then you'll probably get away with using it.
But don't expect it to start a heavy load.
A capacitor smaller than 45MFD should give you a gentler start. Experimenting with your apparatus will let you optimize it , if you want ..
Good luck and thanks for the feedback. We all enjoy a vicarious victory.
old jim
  • #64
It will not be used with light loads so I will stick with your original recommendation. I am still a long way off in that I do not have a frame fabricated, pillow blocks, rollers, etc. as of now. First concern is getting the motor operating.
I've only checked the supply house in the next town over and they wanted $30.48. I will check a couple more local (Tulsa) before I order one online.
Thanks again.
  • #65
Small World - i was just in Tulsa . try Associated Parts & Supply over on Admiral Place...
old jim
  • #66
I will and thanks again.
  • #67
PS you might consider making your pulley arrangement to accommodate the motor's high speed . Reason is its cooling fan will turn faster giving more airflow over the windings.
  • #68
The project is on hold for now. I am trying to get some painting done while the weather is nice.
  • #69
Just found this thread on reusing the clothes washer motor after a quick Google. I salvage the same two speed motor out of a clothes washer that wore out but still had a good motor in it. With the help of all the great information posted here I was able to reuse it to power an old Kelley K-9 honey extractor made back in the 60's. I've been a bee keeper for years and hand cranking the extractor isn't a lot of fun with a large honey crop.
The conversion was pretty straight forward using the 1080 RPM low speed setting and belt drive to a 10 inch pulley. The motor came with a 2 inch pulley on it so I ended up with about a 5:1 reduction with a final speed of just over 200 RPM.
First time through I had to give the extractor a little push to help get it started so I added a 60 uf run capacitor to the circuit instead of the 45 uf capacitor that came with the motor. The 60 uf cap alone was an improvement but once the extractor is loaded I'm sure it will need the full 105 uf to get up to speed so I wired the 45 uf into the circuit in parallel to the 60 uf cap.
I have a 8 minute video of the conversion and operation of the extractor over on U-Tube but not sure if I'm allowed to post it or link to it.
Thanks everybody for this thread, it helped a lot with re purposing the motor.
  • #70
Here's the U-Tube video of the conversion or upgrade. The extractor was purchased by my dad back in the 60's but not used much. After his death in '91 I grabbed all the bee keeping equipment and started with bees. Since then I've been an off and on bee keeper and currently run about five or six hives in Florida which produce about 15 to 20 gallons of honey a year. For my best year I produced 45 gallons which was a real work out with hand cranking the extractor and made me decide to work on motorizing it. The exterior of the extractor looks rough after 50 plus years and my next project will be to sand and clean it up with a coat of battleship grey paint on it's outside.
Hope everybody enjoys the video, the extractor isn't close to OSHA regulations but it's a work horse and built better than most currently offered nowadays. Just need to keep your fingers out of it when spinning. LOL
  • Love
  • #71
Jim, hope you are still around since this is 2021. I have same motor as you used for your photos on the first page and I'm looking to wire it for fwd and Rev with all three speeds. It looks like low speed winding (terminal 9, w-or wire) is is energized anytime terminal 8 (orange wire) is energized as they are connected inside the terminal block, so it looks like low is energized anytime high is not. Am I looking at this wrong?
  • #72
Alas, our beloved Jim Hardy passed away. R.I.P. Jim. He is sorely missed.
I do have links to two videos that may help. Maybe not. It sounds like you're at a pretty advanced stage of knowledge already.
  • #73
I think of him very often. I can still visualize him when he was setting in my rocking chair.
:oldcry::oldcry::oldcry:
  • #74
Sorry to hear about Jim, he was wealth of information. Thanks for the videos, I haven't looked at them yet, but will before I put electricity to any of the windings. Had a Retired Navy electrician chief (non-practicing) look at a close up of the terminal block and washer schematic. He concurred that my observation was correct but did not see it as a problem. He said that I could disconnect the motor wire from the terminal and connect it directly to the power coming from low/med speed 3-way switch that I will be using. I'll follow up with results just in case anyone else stumbles across this blog looking for help wiring 3 speeds for this motor. Thanks!
  • #75
I haven't tried it, but looking at an earlier post starting in reverse may work if you reverse the connections to the start winding. That does mean that the motor must be at a dead stop, no reverse-while-running allowed!
jim hardy said:
Before it starts, Bm does not rotate just oscillates in the vertical plane. So the rotor does not know which way to turn.
That's because a vertically oscillating magnetic field can be represented as two uniform ones rotating in opposite directions
and the rotor is happy to follow either one after you nudge it in either direction.
That's key to motor theory - a rotating flux must have two components and their angle must not be 180 degrees. The start capacitor and its winding give you that phase shifted component , it's exact angle is not critical but somewhere around 90 degrees works best..
That's why there is a start winding, to provide rotation to Bm until the rotor has begun spinning. Once that happens it'll follow whichever component of Bm you picked and you can disconnect the start winding.
Let us know what you find.
I can't help with the 3 speeds though.
Cheers,
Tom
  • #76
Yes, I'll be using a 4 way switch on the start winding circuit. Since start winding power drops out after the centrifugal switch activates, changing the switch position while motor is running will not have any impact until the next start. May power it up this afternoon and If everything works like expected, I will post a detailed schematic of the setup (based largely on Jim's fantastic work).
  • #77
Good news! I was successful in starting forward and reverse and running all three speeds. Speeds were about 50 rpm higher than motor rating, but that may be the result of inaccuracies in my meter or power company running a little higher frequncy. Haven't tried depinning low speed wires from motor terminal block and just connecting together, but I'll do that this afternoon. Detailed schematic and photos will follow when I'm confident I have everything spot on.
  • #78
Update. No discernable difference in parameters or operation when bypassing motor terminal block for low speed windings so I returned to original configuration. Look for a schematic before end of week (want to take my hand drawn diagram and recreate in a graphics program at work). Some pics, including hand drawn schematic, attached. Only thing I'm missing is the 15 amp in line fuse, but I have that on order.
Pic 1 is hand drawn diagram. Look for better one later this week.
  • #79
Pic 2 is motor terminal block with all wires connected.
  • #80
Pic 3 is general shot of motor, harness, and switches. 2 way for on/off in single gang box. 4 way and two 3 ways in 3 gang box. 4 way (left) controls fwd or Rev start by switching direction of current flow through start winding. 3 way (center) controls fast or medium/low. 3 way (right) controls medium or low speed. I left harness at original length to give me plenty to work with.
(Just figured out how to add pic directly instead of as attachment)
  • #81
As promised.
  • Love
  • · Replies 19 ·
48K
28K
