Twins flying at the speed of light in opposite directions
The discussion revolves around the implications of special relativity, particularly the twin paradox, and how it relates to aging and time dilation. Participants explore the effects of traveling at relativistic speeds on aging, both for humans and hypothetical objects like rocks, while questioning the pedagogical approaches to teaching these concepts.
  • Some participants propose that if two individuals travel at the speed of light in opposite directions, they would age normally in their own reference frames but differently in each other's frames.
  • Others argue that since they cannot actually travel at the speed of light, the discussion should assume speeds just below that threshold.
  • A participant questions the meaning of "aging" for inanimate objects like rocks and seeks to understand the fundamental processes at relativistic speeds.
  • There is a discussion about whether the same time dilation effects apply to biological processes, with some asserting that time dilation is not related to biological aging.
  • One participant emphasizes that aging is a measure of time and that time on a moving clock passes at a slower rate compared to a stationary observer.
  • Another participant clarifies that while a traveler moving at relativistic speeds would return less aged than those who remained on Earth, they do not experience a longer life in terms of heartbeats or subjective time.
  • There is a contention regarding the definition of "rate" in the context of aging, with a focus on proper time versus coordinate time in different inertial frames.
Participants express differing views on the implications of time dilation for aging, particularly regarding biological processes and the interpretation of the twin paradox. There is no consensus on how these concepts should be taught or understood.
Limitations include the assumption that aging can be universally defined across different frames of reference, and the challenge of reconciling subjective experiences of time with objective measurements in relativity.
  • #31
Smattering said:
I like this document a lot, but again it explains the problem in numbers. I can walk to from 16th Ave to 17th Ave (one block) while my friend could run around the block to reunite. He would have to run fast, but it wouldn't occur to me that just because he was running around the block and not walking straight, he forced himself to age slower. It sounds like an absurd concept regardless of what the numbers say. This is what I believe a random student imagines because that's how he understands life, and it doesn't appear to make sense.
It doesn't sound absurd any longer once one accepts that laws of physics appear to vary depending on certain circumstances (strange!). Equations seemingly so simple explain all that variation in one number. But for me as a student, both the equation and that simple number lacks any intellectual context. There has to be a better way to explain the variation than graphing it and calculating an equation, it's just too abstract.
(If any of you here teach physics to students, is this a valuable feedback, or complete rubbish?)
  • #32
Smattering said:
I am not sure whether I can agree here. If the unaccelerated path maximizes proper time, then to say that acceleration does not play a role, seems a bit exaggerated to me. It might not be the root cause, but it certainly plays a role.
kinimod said:
I am now understanding the following: In non-inertial reference frame the laws of physics vary depending on the acceleration of that frame (with respect to some inertial frame).
Now see here is a typical example of the misconceptions that arise from attributing time dilation to acceleration. Acceleration does not change the laws of physics. A non-inertial observer will experience forces of inertia, but the laws of physics definitely do not change.
  • #33
Oh well. I'm back to square 1 on then :-D
  • #34
Which is good, because I think you need to step even further back and reevaluate your basic assumptions. The first thing you need to revise is your understanding of what time is. You need to let go of the notion that there is any kind of notion of a time which is universal. I know it is difficult, it is a notion that seemed obvious to humanity for thousands of years, but which is disproven by relativity. Once you have accepted that, you may be ready to continue your study of relativity. The only notion of time in physics is what a "clock" measures (a clock can be anything with processes that occur at some given rate) and this will generally depend on the path the clock takes through space time.
  • #35
OK, I get this. And clock is an artificial instrument. Let's take atomic clock. What physical events specifically make two equivalent atomic clocks behave differently should they be in motion on different curves in spacetime? There must be some variation that causes this, more specifically than just saying "it's the Time Dilation that does this" (too broad).
  • #36
kinimod said:
What physical events specifically make two equivalent atomic clocks behave differently should they be in motion on different curves in spacetime?.
It's not specific. It affects all clocks and processes, so we interpret it as time passage itself, not some clock specific behavior.
  • #37
No, you are wrong. Apart from what A.T. already said. What makes you think that the clocks should behave the same regardless of the state of motion? That thought is a thought that has been disproved, although it works as a good approximation in most cases with which we are familiar - it is simply not how Nature works. Physics is about finding a good description of observations, not about finding underlying "mechanisms". In a given model, its basics are the physics and the model will be judged based on its predictions. The predictions of relativity are very successful in making predictions which have been experimentally verified.
Your assertion of "there must be some variation that causes this" is exactly what you have to let go of. It assumes that there is some underlying "true" time. There is no physical time apart from those which can be measured by clocks, which will depend on the state of motion. This is an experimental fact.
  • #38
I understand that asking "why two clocks on different curves show different time" is the same as asking "why two clocks on the same curve show the same time"... The "why" part of the question starts with an assumption that it should be otherwise.
In that case I am like a child asking a parent an indefinite tree of "but why" questions, expecting that there's some ultimate underlying mechanism at the end that explains Everything.
So, is it that modern physics simply does not explain underlying causes or mechanisms for variations observed in aging, clocks, or muon decay? There's just no value in researching/defining it for "ultimate clarity", because the model we have today for observing it is completely predictable and satisfactory already? ...Or it's just because it's the same nonsense for 21st century physics as asking "why is there something instead of nothing"?
  • #39
At some point you will have to realize that this approach is actually unscientific if you want to devote yourself to an experimental science such as physics. Physics as such does not deal with ultimate underlying explanations of Everything. It deals with the description and prediction of experimentally observed effects. Naturally, given a model which has a large number of predictions, there will be explanations within that model, but this is not the same thing as the need of an underlying mechanism of everything. In the end, if there was such a mechanism, you would still be able to ask the question "why that mechanism?" and therefore render that question unscientific as there can be no scientific answer but only philosophical ones.
  • #40
I am imagining an accelerating atom in which electrons have to "compensate" and behave differently to remain in an atom structure -- compared to electrons in another hypothetical atom not undergoing acceleration.
Consequence of that is e.g. muons decaying differently...
You are still trying to find a "way out" that enables you to keep a concept of absolute time and decline to accept what time dilation is. Your examples are good examples of what I was referring to previously: no such mechanism for acceleration (or as Orodruin said, constant speed motion too) affecting the rate of chemical processes is known. worse, such a mechanism would not apply to radioactive decay processes, so you'd need a different mechanism to explain that.
Note that if what you suggest about acceleration were true, then time dilation would not depend on how long the two observers remain in constant speed motion between acceleration events. But it does. Indeed, for simple analysis, the acceleration events are ignored and it is assumed they "jump" to their new speeds.
Nope: you're still not accepting what time dilation is. You have to stop looking for these physical processes: they do not exist.
It certainly does, but the one "mechanism" that modern physics has discovered is the one mechanism you do not want to accept.
  • #41
What do you mean by "physical event" and why do different world lines of two observers in spacetime not qualify as "physical events"?
There *is* a "variation" that causes this. You already mentioned it. It's the different world lines of the two observers in spacetime.
  • #42
But there is indeed an ultimate underlying mechanism. The ultimate underlying mechanism is the existence of an upper bound for the relative speed of two objects. This upper bound is usually referred to as the "speed of light in vacuum", and it is constant for any observer. *This* is the ultimate underlying principle.
The variations observed in aging, clocks, or muon decay must be the way they are, because otherwise, this absolute upper bound on relative speeds could not exist. Either you have absolute time or you have an absolute upper bound on relative speed. These two possibilities exclude each other. Only one of them can be true.
And the experimental data clearly tells us which of these two possibilities is correct.
  • #43
I know what you are saying here, but I am not sure that is the best way to say it. What you are saying is that it is possible to write the laws of physics in a manner which is the same in all coordinate systems. This is what you are envisioning by "the laws of physics", but since this thread is labeled "B" @kinimod probably has never seen those mathematical tools.
Equations of physics can also be written in terms of coordinates. This is probably the math that the OP has seen, and what s/he envisions by the phrase "laws of physics". When they are written in terms of coordinates then the coordinate based physics equations are different in accelerating coordinates vs inertial coordinates.
@kinimod, modern scientists typically think of the laws of physics in terms of these coordinate independent mathematical tools. Using those tools you can easily rewrite things in terms of any set of coordinates. Non accelerating coordinates are called inertial, and those are the coordinates that are used in introductory courses. If you rewrite things in terms of accelerating coordinates then you will get different expressions. These differences are attributed to the change of coordinates rather than a change in the laws of physics. Hence Orodruins comments.
  • #44
Can you tell me the underlying cause or mechanism for the fact that the length of the hypotenuse is less than the sum of the lengths of the other sides? From modern physics' perspective it is basically the same.
Edit: fixed mistake in greater than vs less than
  • #45
DaleSpam said:
Can you tell me the underlying cause or mechanism for the fact that the length of the hypotenuse is greater than the sum of the lengths of the other sides? From modern physics' perspective it is basically the same.
Coincidentally, I just submitted an Insight discussing this issue for review. If it passes Physics Forums very strict peer review procedures, it should be available relatively soon. :rolleyes:
Edit: Here it is https://www.physicsforums.com/insights/geometrical-view-time-dilation-twin-paradox/
  • #46
There are physicists who are looking for "deeper" theories that lie "underneath" our current theories (models). String theory, quantum gravity, the various interpretations of quantum mechanics...
In order for any of these new theories to be accepted completely, they need not only to be consistent with the body of experimental data that supports our current theories, they also need to predict something "new" that can be tested experimentally. Otherwise, how do we choose between multiple competing theories? Without experimental tests, all we can do is argue about which alternative is "prettier" or better satisfies preconceived notions about how the universe "should" work? That's the situation we're in right now with interpretations of QM (Bohmian mechanics, many-worlds, etc.). They're constructed to reproduce the predictions of standard QM, which so far has withstood all experimental tests. Choosing among them is basically a matter of personal philosophical preference.
  • #47
Surely you meant "less than the sum", unless those are spacetime intervals. :wink:
  • #48
The "underlying cause or mechanism" is the metric at use.
  • #49
Which is exactly what Dale said in a language more accessible to someone starting a B-level thread.
  • #50
oops. Yes. I will fix it. Thanks for catching my mistake.
  • #51
The "why" for as far as we can take it, it that the measurement of time and space differs between inertial frames with relative motion with respect to each other. The best way I can think of for you to picture this is to imagine a "map" of time and space. Just like a normal map our space-time map has the equivalent of a North-South and East-West direction. We can think of North-South as time and East-West as "space" Now in this map we have limited space to one direction and it really has 3 dimensions, but we will limit it to one so we don't have to try and visualize four dimensional map and It simplifies the example without affecting the salient points.
So now that we have our map, we can place points on it and call them "events" with an event describing something at a particular place and time. (the corner of 5th and Elm at 5:00pm). If we have two events, we can tell how far apart they are in time and space by their locations on our map. So two events can be 4 miles and 3 hrs apart. Now imagine this map as really large with people standing on it, all of them facing different directions. Ask anyone of these people about these events and they will say that they are 4 miles apart and 3 hrs part (just like anyone looking at a typical road map would say that town A is 30 miles to the North and 40 miles to the East of town B.)
This was pretty much the way time and space were viewed before Relativity. What Relativity has revealed to us is that the North-South, East-West way of distinguishing between time and space doesn't work; That, in fact, we need to treat it more like front-back, left-right, and unlike North-South, East-West, front-back, left-right is not something that everyone agrees on. In our example above, two people facing different directions will give different answers for the relative position of the two events. One might still say that they are 4 miles and 3 hrs apart, but the other could say that they are 5 miles apart and happened at the same time.
Now to make this analogy a bit more complete, our people are not allowed to stand still. They all have to be walking at the same pace. And since for each person, time is in the direction he is facing, this means he is always moving forward in time. If two people are facing different directions, their paths will converge or diverge, so from either person's perspective, as time passes the other person gets closer or further. Put another way, they have a relative motion with respect to each other.
So considering the above, let's use the example of two men, walking side by side. They are facing the same direction, thus they measure time the same, they are not moving apart, so they have no relative motion with respect to each other. Since they both see each other as progressing through time at the same rate, they see each other as aging at the same rate.
Now one man, call him A. changes direction and is now walking in a different direction then B. Consider what happens to him as seen by B. B sees himself progressing forward through time at his normal rate unchanged. But when he considers A, he notes that he is no longer remaining a breast with him, he is falling further and further behind. Since by his measure, time progresses in the direction he is walking, then, by his measure, A is making less progress in time, or is aging slower.
If we consider things from A's perspective, he sees himself as progressing normally through time, while B is not, So A sees B as aging slower. This is time dilation. Note that this is not due to some outside influence effecting how fast either man walks (ages), but due to the fact that they measure "time" differently.
Now consider what happens if A changes direction again, so that he is once again walking in the same direction as B. From B's perspective, this means he stops losing ground as far as aging goes and he once again begins to age at the same rate. However he doesn't make up the ground he lost and remains younger.
What happens according to A? Well, as he turns, B's position with respect to him will change. Just like and object behind you can become in front of you by your turning towards it, B, according to A goes from being "behind" to "in front" when A changes direction. Since progress in time is still defined by A as the direction he is facing moving, A suddenly sees B progress ahead of him in time. Or put another way B ages quickly as A turns toward him, so that by the time A and B are walking in the same direction again B is older than A according to A, ( just as is true for B)
A can continue his turn until so that his new path cuts across B's path. As he turns B will move even further " ahead" in time. After the turn, he will note that B once again is progressing slower through time than he is. However, by the time he crosses B's path again, this slower aging will not be enough to make up for the gain made during the turn, and B will still be older. A can then turn to "follow" A. So A will have returned to the same point in space as B, but will had made less progress through time. Put another way, A traveled away from B, turned around and returned to B, having aged less during the trip. All without some outside influence acting on A or B.
I realize that it seems a bit 'unnatural' for time and space to behave this way. But that is just because through the vast majority of man's history on Earth we were only used to dealing with velocities that were so slow, that these effects were just too small to notice and had no effect on everyday life, so we didn't know they were there.
As to "why" time and space behaves like this, that delves into a lot deeper level of "why".( And the funny thing about "why" questions is that no matter how far you dig, you will always find another "why" underneath.)
  • #52
The underlying cause is that time itself has these "variations". Once you accept that, it explains the variations in aging, clocks, and muon decay.
You can go further and ask why. And the reason is that inertial reference frames are equivalent. The speed of light is the same in all of them.
You can go further and ask why those things are true, And maybe it goes that way forever or maybe it doesn't. Maybe there's some fundamental thing that can't be explained. This is not some issue arising in modern physics. It has always arisen in physics, and every other human quest for knowledge.
Physicists create models that explain the way nature behaves. The models are not tangible items like a fossil that lay hidden to be discovered. They are products of the human intellect. They are products of human imagination. Many people expect these models to be more than that. That they somehow are the things they model.
Time dilation is a difficult thing to teach to people. It confuses them when they first hear about. Anyone who isn't confused isn't engaged. This is often the way of it when we introduce new ideas into our worldview. We are always confused until we understand the new idea.
  • #53
DaleSpam said:
They do each age normally in their own reference frame. They each age slowly in the other's reference frame.
Ouch! This seems to be logically problematic.
  • #54
kinimod said:
If two guys, each sitting on a different Earth-like habitable planet, fly in the opposite directions, each at the speed of light, which guy would age slower? And slower compared to what?
My own understanding is that they both age normally. Because Special Relativity doesn't describe physiological processes, but only hints at visual disparity of the spacetime (photons can't travel fast enough to observe the reality from any given reference frame).
If this is true then the whole twin paradox is a very unfortunate way of teaching kids, just creates confusion...
They would not see each other "NOW". They would each see the image of the other after light had traveled for minutes or hours. They would see each other slowed down due to the doppler shift, and would compute the other's time as traveling slowly. As long as they travel apart, they will never meet again, so there's no way to verify who is "really" aging slower.
Assume Alpha Centari is exactly 4 light years away, and one twin is
traveling
there at 4/5 speed of light. (Using a 3,4,5 triangle I avoid
irrational numbers in my computations.
Traveling at 4/5 the speed of light, from the point of view of the
stay at home twin, the trip will take 10 years, 5 years there, 5 years
back.
Time for the traveller T’ = T( sqrt( 1- (v^2/c^2))) = 3/5 T
Likewise, the distance for the traveler, D’ = 3/5 D
The traveler on the spaceship sees himself traveling a distance of
4*3/5 = 2 2/5 light years in a time of 3 years, and likewise the 2 2/5
light years back
in a time of 3 years, so the traveler will see the trip as lasting 6
years.
Say the twins have super telescopes and can see each other throughout
the trip.
As long as they are traveling apart, the twins will see each other as
aging at 1/3 speed. As long as they are traveling towards each other,
the twins will see each other as aging at triple speed.
The difference is, the traveling twin will see the stay at home twin
as aging at 1/3 speed for the 3 years to Alpha Centauri, for a total
of 1 year,
and at triple speed for the 3 year trip back to Earth = 3*3=9.
The traveling twin will see the stay at home age 1 year during the
trip out, and 9 years during the trip back, for a total of 10 years.
The stay at home twin will see the travel age at 1/3 speed for 9
years, the 5 years it takes the traveler to get to Alpha Centauri,
plus the 4 years it takes the light to get back to earth. Since the
total trip will take 10 years, the stay at home twin will see the
traveler age at triple speed during the one year he observes the
traveler coming back to earth. The Earth observer sees the traveler
age at 1/3 speed for 9 years, for a total of 3 years, and at triple
speed for 1 year, for another 3 years, giving 6 years for the round
trip.
Both observers see each other aging at the same slow rate while moving
apart, they see each other aging at the same fast rate while moving
together. The difference lies in one observer deliberately changes
the relative motion of his rocket from moving away from Earth to
moving towards earth, and the other observer remaining passive, and
not seeing the change until the light from the
traveler reaches earth. If the Earth could be accelerated like a
rocket ship, and the earthbound observer decided to change his frame
so the rocket appeared to be moving towards him at 4/5 lightspeed
rather that away at 4/5 lightspeed, while the rocket remained in
motion past Alpha Centauri, then it would have been the Earth twin who
appeared to age less.
Of course you could have some intermeditate situation where BOTH
observers decide to change their relative motion before they see the
other observer change his motion.
  • #55
It is no more logically problematic than my analogy of two men walking in different directions from a single origin. Each man is walking normally as far as he is concerned, but he will also note that the other man is falling behind. (he will have to crane his neck more and more to look at him.). In other words, each sees the other man as making slower progress in the direction he himself is walking.
It may seem counter-intuitive to treat time this way, but this is simply due to the fact that in our everyday environment we are not exposed to the type of velocity differences that makes this type of behavior apparent. If we had evolved in an environment where relative velocities of a good fraction of c were common, we would take this as being perfectly natural.
  • #56
I'm kind of amused at all of the overly technical explanations in this thread.
Here's the simplest explanation I can give:
The faster you move, the slower time moves. But slower implies comparison, time is moving slower for you compared to what? Anything moving slower than you are, really. But let's take the twin paradox.
If you send your twin off at (close to) the speed of light, time will pass more slowly for your twin than for you. But what does that mean? Your twin will see a clock on the wall on his spaceship move like an ordinary clock. For your twin, time appears to be moving normally. But if you had a time/space visualizer and tuned it into watch your twin on his spaceship, everything on your twin's spaceship would appear to be moving in extreme slow motion. This is what we refer to as reference frames: your reference frame is the universe around you, all moving "together". When your twin takes off in his ship, his ship becomes a separate reference frame. Everything inside the ship appears normal, but outside the ship looks very different because of the difference in speed.
So #1: Time is not a constant. The passage of time is not a constant.
To answer the original question, how fast you and your twin "age" (ostensibly, how faster or slower time appears to move) depends on who is observing and what their reference frame is. Some observer standing at the point of origin with a time/space visualizer would see you both age (time passing) at the same rate as each other (but much more slowly than for him), since you are both traveling at the same speed relative to the observer.
Hopefully this is a little more comprehensible to the layman than some of the more technical answers in this thread.
  • #57
If one tries to explain the twin paradox without invoking relativity of simultaneity then chances are near 100% that the explanation will be poor. If the explanation depends on an absolute frame of reference, the odds worsen.
Possibly the best advice about posting in a twin's paradox thread is to do so quietly and wash your hands after.
The notion of "moving slower than you" appears to implicitly assume the existence of an absolute reference frame.
The mental image conjured by the phrase is of a piece of hardware that actually measures something. That is a misleading suggestion. This "time/space visualizer" is not a feature of the universe at all. It amounts to one's choice of coordinate system. A mere accounting gimmick. Any choice will do. It need not be anchored to the universe or to any particular object.
The phrase "difference in speed" is questionable. It suggests the existence of an absolute reference frame in which velocities are subtracted.
When the twin takes off in his ship, his ship does not become a separate reference frame. It happens to be at rest in a new and different reference frame. The traveling twin can still directly observe his wristwatch ticking away at one second per second. If the traveling twin tunes his "time/space visualizer" to read zero speed for the outbound ship then it will agree that time is passing normally for the traveler and slowly for the stay-at-home twin.
When the traveling twin turns around and re-tunes his "time/space visualizer" to read zero speed for the return trip, there is a problem. How old was the stay at home twin before re-tuning the visualizer? How old was the stay at home twin after? That is the problem of relativity of simultaneity.
  • #58
Why?
Edit: it is easier to see that there is no logical problem if you write it down clearly. If ##r_{clock,frame}## is the rate of a given clock with respect to a given frame then "they each age normally in their own frame" means ##r_{A,A}=1## and ##r_{B,B}=1## while "they each age slowly in the others frame" means ##r_{A,B}<1## and ##r_{B,A}<1##. There is no logical problem with that.
  • #59
It seems the Doctor Who reference was completely lost. The idea is of a magical "window" that peer into another reference frame and yet let's you observe it relative to your own. Of course no such feature of the universe exists. But neither does a cat in a box with a poison capsule and a radioactive isotope.
As I read over this thread, it seemed the OP was having difficulty understanding the idea that time is not a constant, and none of the responders seemed to be addressing that in a way that made sense to the OP. My illustration (hopefully) suffices to convey the idea that time is not constant, but you're absolutely right that it loses quite a bit of technical accuracy in the process of simplifying it down to that key concept. Kind of like the movie Interstellar.
If the inaccurate illustration serves the purpose of conveying the idea, then you can feel free to correct all of its inaccuracies once the OP understands the context of time not being a constant.
  • #60
DaleSpam said:
Why?
Sorry Dale. I wasn't questioning your math. And I'm certainly not disputing the validity of relativity. I was simply making the observation that the statement (each of the travelers aging slowly relative to the other within their own reference frame) APPEARS on its face to be a logical conflict. It would intuitively (while admittedly naively) seem impossible for both of those situations to be true "at the same time". I think that is the OP's primary confusion.
Perhaps the OP's confusion is not so much that "time" isn't constant, but rather that the general experience of "now" is not constant.
I think Briggs makes that point very well here. If the twins were traveling at their identical "near light speed" velocities in a circular path in opposite directions, they would be the same age when they met again at the starting point. The total time elapsed would be precisely the same for both twins. The only variation would be with regard to when "now" was for either of the twins at any given time... which would (again naively) appear to require an absolute time reference clock to compare the two.
  • · Replies 42 ·
  • · Replies 35 ·
  • · Replies 20 ·
  • · Replies 38 ·
  • · Replies 45 ·
  • · Replies 58 ·
  • · Replies 48 ·
