Two, atleast to me, perplexing chem problems
  • Thread starter Thread starter relativitydude
    Chem
To calculate the pH at the equivalence point when titrating a 0.10 M solution of HBr with 0.08 M NaOH, it is suggested to use symbolic volumes for the acid and base, as the specific volume is not necessary for determining the pH. The equivalence point pH is typically 7 for strong acid-strong base titrations, but clarification is needed on whether HBr is treated as a strong acid in this context. For calculating the equilibrium constant for the reaction involving Ag2S and AgCl2, Kf refers to the complex formation constant, which is given as 1.1x10^5 for AgCl2. To proceed, it is recommended to express the reaction with all charges and consider the possibility of needing Ksp for Ag2S and the dissociation constants for H2S. Multiplying the Kf value by 2 may also be a step in the calculation process.
relativitydude
1) Calculate the pH at the equivalence point in titrating 0.10 M solution of HBR with 0.08 M NaOH
I know how to do the problem if volume amounts are included. I don't know how many liters are used and consequently the number of moles. Should I just invent some volume for one and calculate the pH based on how much the other takes to titrate it?
2)I need to calculate the equilibrium constant for
Ag2S + 4CL + 2H <---> 2AgCl2 + H2S
The only information provided is Kf (what the heck is Kf?) is 1.1x10^5 for AgCl2
How does one proceed? Thanks! :)
Chemistry news on Phys.org
You may try with volumes - say - Va and Vb (for acid and base) - and do the symbolic calculations first. Volumes will cancel out at the end, as the only important thing here is the ratio of concentrations - to neutralize Va HBr solution you need 0.1/0.08*Va NaOH solution, so total volume at the end is (1+0.1/0.08)Va and so on.
Try my BATE (see footer for link) for such calculations of pH and titration curve.
Kf stands probably for complex formation constant. Next time write the equation with all charges, it will be much easier to understand. I wonder if it is possible to find answer without Ksp for Ag2S and Ka1, Ka2 for H2S... Ksp for AgCl s not a problem, as it is easy to remember (1e-10).
Chemical calculators for labs and education
BATE - pH calculations, titration curves, hydrolisis
You're asked for the pH. It'll be 7 at equivalence point. The equivalence point is when all of the strong acid/base has reacted with the strong base/acid. Perhaps HBr isnot considered a strong acid, then you'll need to know the Ka.
I believe what you can do here to is to multiply the Kf by 2
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
