AbigailM
- 46
Two blocks A and B with respective masses m_{A} and m_{B} with respective masses m_{A} and m_{B} are connected via a string. Block B is on a frictionless table, and block A is hanging at a vertical distance h from a spring with spring constant k that is at its equilibrium position. The blocks are initially at rest. Find the velocity of A and B when the spring is compressed by an amount \delta y =m_{A}g/k. Determine the maximum compression \delta y_{max} of the spring in terms of m_{A}, m_{B}, g and k. (Hint: what happens to the motion of the blocks when \delta y-m_{A}g/k?)<br /> <br /> <h2>Homework Equations</h2><br /> \delta y=m_{A}g/k (Eq 1)<br /> <br /> (m_{A}+m_{B})gh=\frac{1}{2}(m_{A}+m_{B})v^{2} (Eq2)<br /> <br /> \frac{1}{2}m_{A}v^{2}=m_{A}g\delta y - \frac{1}{2}k\delta y^{2} (Eq 3)<br /> <br /> <h2>The Attempt at a Solution</h2><br /> From Eq2 v_{B}=\sqrt{2gh}<br /> <br /> Solve Eq3 for v and substitute in Eq1. Then we can subtract our new equation from Eq2:<br /> v_{A}=\sqrt{2gh}-\sqrt{m_{A}/k}g<br /> <br /> To find \delta y_{max} substitute v=\sqrt{2gh} into Eq3:<br /> m_{A}gh=m_{A}g\delta y - \frac{1}{2}k\delta y^{2}<br /> <br /> Now solve for \delta y:<br /> \delta y=\frac{m_{A}g-\sqrt{m_{A}^{2}g^{2}-2km_{A}g}}{k}<br /> <br /> Does this look correct? Thanks for the help
