Two boxes are on frictionless ramps (Speed and KE)
  • Thread starter Thread starter Koskesh
    Frictionless
Two boxes on frictionless ramps are analyzed for speed and kinetic energy after being released from the same height. Box 1, being lighter and on a steeper ramp, is expected to have a greater speed due to the influence of gravity on the slope. Conversely, Box 2, which is heavier and on a less steep ramp, is anticipated to have greater kinetic energy at point B because of its higher mass. The discussion emphasizes the conservation of mechanical energy, indicating that both boxes start with gravitational potential energy that converts to kinetic energy as they descend. Ultimately, the analysis leads to the conclusion that while Box 1 may be faster, Box 2 possesses greater kinetic energy at the bottom of the ramps.
Koskesh
Two boxes are resting on frictionless ramps. Box 1 is lighter and sits on a steep ramp while Box 2 is heavier and sits on ramp that is less steep. The boxes are released from the same point.
Which box (if either) has
a) The greater speed?
b) The greater kinetic energy at B
Box 1 = Lighter and steeper ramp
Box 2 = Heaver and less steep ramp
Initial starting point = A
Displacement = B
I'm sure its wrong. I don't really have a concise explanation.
a) Box 1 should have the greater speed because gravity will produce a greater effect on a higher slope.
b) Box 2 should have greater kinetic energy at B because it has more mass and thus can create higher momentum.
Hint: Consider the fact that mechanical energy is conserved on the frictionless ramps. What can you deduce from that?
Meaning there is no kinetic or potential energy present? So then neither box would be quicker than the other?
:confused:
What's the initial energy of each box? The final energy? How do the speeds compare?
Hmm.. no initial energy? Marketing grad here boss, bear with me.. lol.
Both boxes start out at some initial height (presumably the same for both boxes) so they have gravitational potential energy. What's the expression for gravitational PE as a function of height (with respect to the ground)?
Work? F x D?
Expression for Grav. Potential energy when the body is close to the earth?
Koskesh said:
Work? F x D?
That is the work done by a constant force F over a displacement d.
Think about the expression for grav. potential energy..
