Naeem
- 193
Q. At t = 0, an object is projected with a speed v0 = 30 m/s at an angle q0 = 30° above the horizontal. The axes on the diagram show the x and y directions that are to be considered positive.
For parts a-g, calculate the requested quantities at t = 10 s into the flight. ( Use 9.81 m/sec2 for g. )
a) The vertical acceleration of the object:
ay = m/s2 *
HELP: What force is acting on the object in the vertical direction?
HELP: Is it moving faster or slower as it travels upward?
b) Its horizontal acceleration:
ax = m/s2 *
0 OK
c) Its vertical velocity:
vy = m/s *
-83.1 OK
HELP: Use the definition of acceleration.
d) Its horizontal velocity:
vx = m/s *
25.98 OK
e) The angle to the horizontal at which the object is traveling (an angle above the horizontal should be reported as a positive number; an angle below the horizontal should be reported as a negative number). Please give your answer in degrees:
angle = ° *
-72.59 OK
f) Its vertical displacement, from where it started:
y = m *
-340.5 OK
HELP: Look at the equations in your book.
HELP: Look for an equation relating initial velocity, change in position, acceleration, and time. Use your previous answers.
g) Its horizontal displacement, from where it started:
x = m *
259.8 OK
h) At what time does the object reach its maximum height?
ty, max = s
2*83.1*sin(72.59)/9.81 NO
I just need some help with part h.
At the max, height final velocity is zero, I know that
I tried using t = v_y/g
and plugging this into
y-yo = v0sintheta*t - 1/2 g* t^2
didn't work!
Pl. Help
ay = m/s2 *
ax = m/s2 *
0 OK
vy = m/s *
-83.1 OK
vx = m/s *
25.98 OK
angle = ° *
-72.59 OK
y = m *
-340.5 OK
x = m *
259.8 OK
ty, max = s
didn't work!
Pl. Help
