Two heat/temperature problems
  • Thread starter demode
In summary, the conversation involves a question about the temperature change of a mass of water with a specific amount of heat loss, and a follow-up question about the heat required to raise the temperature of a larger mass of water by a larger amount. The solution to the first question involves using the specific heat capacity of water and the amount of heat loss to calculate the temperature change. The second question suggests using an equation that takes into account the specific heat capacity, mass, and temperature change to determine the amount of thermal energy needed.
demode
30
1. How many celsius degrees does the temperature of a mass of 1.00 kg of water fall for each 83.8 kJ of heat it loses.
2. Not so sure about EQUATIONS but I have my own way of going at it.
3. 83.8 kJ / 4.19 J * (1.00 kg * 1000) = 0.2 degrees celsius
1. How much heat is required to raise the temperature of a mass of 10.0 kg of water a total of 20.0 celsius degrees.
3. IF it takes 4.19 j of heat to raise the temperature of 1 gram of water by one degree celsius, how do we factor in the larger mass of 10,000 grams and the larger temperature change of 20 celsius degrees?
Your solution to the first question is correct. For the second, you should consider an equation relating the specific heat capacity of water, its mass and the change in temperature to thermal energy. I'm sure you will have been given some formulae in your notes/text.
1. The amount of heat required to raise the temperature of a substance can be calculated using the specific heat capacity of the substance. In the case of water, the specific heat capacity is 4.19 J/g°C. Therefore, the amount of heat required to raise the temperature of 10.0 kg of water by 20.0°C can be calculated as follows:
Q = m * c * ΔT
Where Q is the amount of heat, m is the mass, c is the specific heat capacity, and ΔT is the change in temperature.
Substituting the values, we get:
Q = (10.0 kg * 1000 g/kg) * (4.19 J/g°C) * (20.0°C) = 838,000 J or 838 kJ
Therefore, 838 kJ of heat is required to raise the temperature of 10.0 kg of water by 20.0°C.
2. It is important to use equations and proper units when solving scientific problems to ensure accurate and consistent results. In this case, using the specific heat capacity equation allows us to factor in the mass and temperature change of the water in a precise manner.
1. What is the difference between heat and temperature?
Heat refers to the transfer of thermal energy from one object to another, while temperature is a measure of the average kinetic energy of the particles in a substance.
2. How do you convert between different units of heat and temperature?
To convert between units of heat, such as joules and calories, you can use conversion factors. To convert between units of temperature, such as Celsius and Fahrenheit, you can use the conversion formula: F = (C x 9/5) + 32.
3. What is the specific heat capacity of a substance?
The specific heat capacity of a substance is the amount of heat required to raise the temperature of one gram of the substance by one degree Celsius. It is measured in units of joules per gram per degree Celsius (J/g°C).
4. How does heat flow in a system?
Heat always flows from a higher temperature to a lower temperature. This is known as the second law of thermodynamics. The rate at which heat flows is determined by the thermal conductivity of the materials in the system.
5. What is thermal equilibrium?
Thermal equilibrium is a state where there is no net transfer of heat between two objects that are in contact with each other. This means that the temperatures of the two objects are equal and there is no longer a temperature difference between them.
