Two masses on two inclined planes
The problem involves two masses on inclined planes, with one mass known and the other unknown. The left slope has a 60-degree angle and a mass of 2.1 kg, while the right slope has a 20-degree angle and an unknown mass. The discussion centers around determining the unknown mass given specific acceleration values.
  • Mixed
  • Participants discuss applying Newton's second law (F = ma) to both masses, questioning how to incorporate the forces acting on the unknown mass. There are attempts to clarify the components of forces along the slopes and the role of tension in the system.
The discussion is ongoing, with participants exploring various interpretations of the forces involved. Some guidance has been offered regarding the setup of free body diagrams and the need to consider vector components. However, there is no explicit consensus on the approach to take.
Participants express frustration with the complexity of the problem and the amount of information needed to solve it. There are mentions of personal challenges affecting the learning process, and some participants indicate a desire to step back from the course due to the difficulties encountered.
maysenator
If the left hand slope makes a 60 degree angle and the right hand slope makes a 20 degree angle.
the left hand mass is 2.1 kg, and the right hand mass is unknown.
what would the right hand mass be given a downward acceleration of .64 m/s^2. ?
upslope at .76 m/s^2
I have set this problem up to the best of my knowledge and watched tons of videos but cannot grasp it. i think I am not breaking it up enough and i have a picture of my work and how i set it up.
thank you in advance for any help anyone may have to offer
thank you
welcome to pf!
hi maysenator! welcome to pf! :wink:
(try using the X2 icon just above the Reply box :wink:)
call the tension T, and the unknown mass m,
and apply good ol' https://www.physicsforums.com/library.php?do=view_item&itemid=26" (F = ma) twice, once for each mass, in the direction of the slope …
that gives you two equations with two unknowns, so you can solve for m (and T) …
what do you get? :smile:
im a little confused, i don't see how you would do this without knowing the force on the side with the unknown mass,
just get 1.34 N for the known side?
hi maysenator! :smile:
call the unknown mass m
you'll get a force with m in it :wink:
what is it? :smile:
2.09?
my answer sheet says that mass of the second block should be 7.07 kg
my ADHD is never going to let me take in all that i need to to pass this physics class. i can't keep up with so many things going on. in my head it feels like there is something i cannot see that others can. i have been sitting here since 10am and its 3pm now on this one problem about to cry. it shouldn't be this hard i just wish someone could see through my eyes because i don't know what to do
what is it? :smile:
maysenator said:
2.09?
2.09 what?
and why doesn't it have an m in it? :confused:
(and how did you get 2.09 anyway?)
1.34/.64 = 2.09
f = ma?
maysenator said:
1.34/.64 = 2.09
f = ma?
that's 1.34 from the left hand mass?
no, your F = ma equation must be for one mass only
do this slowly and logically …
first thing is to draw a https://www.physicsforums.com/library.php?do=view_item&itemid=100" with all the forces on it
(it must always be only for the forces on that body)
there are three forces on the right hand mass:
the weight 9.8m
the tension T
the normal force​
you know the acceleration parallel to the slope is 0.64
so now look at the diagram, work out what the component of the weight along the slope is, and write F = ma for that direction :wink:
are you saying it SHOULD be for one mass only or that was my mistake?? sorry
again, thank you so much i feel closer already.
this is what i have drawn out so far
no, your free body diagram for the right hand mass should be a slope at 20° with a little box on it
then three arrows from the box, one vertically down marked 9.8m, one along the slope marked T, and one perpendicular to the slope marked N
finally mark the acceleration of 0.64 down the slope (but don;t attach it to the box, and draw it differently from the forces, since it's not a force, so it shouldn't really be there! :wink:)
(and yes, it SHOULD be for one mass only)
but but but i can't find the tension with this information>? i need to use information from the other diagram right??
I don't get what I am missing i have done everything you have said ( i think ) but on my paper i don't have enough information to do anything with?
yes, you need to do a free body diagram, and F = ma, twice, once for each mass
(i thought you'd already done it for the left hand mass)
(the left hand one should give you T, then you put that value of T into the right hand one, to find m)
what are your two F = ma equations?​
i didnt use f = ma for the left one. I thought that 20.58N * sin60 would give the force parallel to the slope
getting 17.83 and then 20.58 cos 60 = 10 . 29 N would the the normal force
so what... then i have ... Fnet = ma~
t1 + 20.58 + 10.29 = (2.1)(.64)
(all the forces?)
is that right? >.<? ( for the left )
(all the forces?)
ah, no …
you're fundamentally misunderstanding the vector nature of F = ma …
force and acceleration are both vectors, and F = ma is a vector equation …
that means you must choose a direction, and take components of F and of a in that direction
try it again, doing it in the direction of the slope :smile:
(btw, no need to call it T1, then two tensions are the same, so just call it T :wink:)
i don't understand what you mean.
the block is moving up the slope at .64 ms
its Fg is 9.8 * 2.1 right?
so i have a, and fg right there.
the normal force is the force the slope is pushing back up into the mass right?
moving in the x direction is Fg * cos 60 right? or Fg sin 60??
so why not plug it in from there?
T + fg + Fn = (2.1)(.64)
thanks for your help man, I am giving up.. dropping the class going to try again next semester
paace
great i can't drop this class because then ill lose my financial aid.
time to commit suicide
(just got up :zzz: …)
because you must use the components (along the slope), not the whole forces :redface:
there are three forces on the left hand mass:
the weight W, the normal force N, and the tension T
ok let's do this slowly and logically …
i] what is the component of W along the slope (up being +ve)?
ii] what is the component of N along the slope (up being +ve)?
iii] what is the component of T along the slope (up being +ve)? :smile:
just wanted to pop back in here and say thanks for the help, was just getting frustrated. ended up getting a decent grade in the class thanks to your help and others from this site.
never taking a calc based phys course during the summer again. I need more time to learn LOL
  • · Replies 18 ·
