Two masses on two inclined planes
21 replies · 4K views
maysenator
If the left hand slope makes a 60 degree angle and the right hand slope makes a 20 degree angle.
the left hand mass is 2.1 kg, and the right hand mass is unknown.
what would the right hand mass be given a downward acceleration of .64 m/s^2. ?
upslope at .76 m/s^2
I have set this problem up to the best of my knowledge and watched tons of videos but cannot grasp it. i think I am not breaking it up enough and i have a picture of my work and how i set it up.
thank you in advance for any help anyone may have to offer
thank you
welcome to pf!
hi maysenator! welcome to pf! :wink:
(try using the X2 icon just above the Reply box :wink:)
call the tension T, and the unknown mass m,
and apply good ol' https://www.physicsforums.com/library.php?do=view_item&itemid=26" (F = ma) twice, once for each mass, in the direction of the slope …
that gives you two equations with two unknowns, so you can solve for m (and T) …
what do you get? :smile:
im a little confused, i don't see how you would do this without knowing the force on the side with the unknown mass,
just get 1.34 N for the known side?
hi maysenator! :smile:
call the unknown mass m
you'll get a force with m in it :wink:
what is it? :smile:
my answer sheet says that mass of the second block should be 7.07 kg
my ADHD is never going to let me take in all that i need to to pass this physics class. i can't keep up with so many things going on. in my head it feels like there is something i cannot see that others can. i have been sitting here since 10am and its 3pm now on this one problem about to cry. it shouldn't be this hard i just wish someone could see through my eyes because i don't know what to do
1.34/.64 = 2.09
f = ma?
maysenator said:
1.34/.64 = 2.09
f = ma?
that's 1.34 from the left hand mass?
no, your F = ma equation must be for one mass only
do this slowly and logically …
first thing is to draw a https://www.physicsforums.com/library.php?do=view_item&itemid=100" with all the forces on it
(it must always be only for the forces on that body)
there are three forces on the right hand mass:
the weight 9.8m
the tension T
the normal force​
you know the acceleration parallel to the slope is 0.64
so now look at the diagram, work out what the component of the weight along the slope is, and write F = ma for that direction :wink:
are you saying it SHOULD be for one mass only or that was my mistake?? sorry
again, thank you so much i feel closer already.
this is what i have drawn out so far
no, your free body diagram for the right hand mass should be a slope at 20° with a little box on it
then three arrows from the box, one vertically down marked 9.8m, one along the slope marked T, and one perpendicular to the slope marked N
finally mark the acceleration of 0.64 down the slope (but don;t attach it to the box, and draw it differently from the forces, since it's not a force, so it shouldn't really be there! :wink:)
(and yes, it SHOULD be for one mass only)
but but but i can't find the tension with this information>? i need to use information from the other diagram right??
I don't get what I am missing i have done everything you have said ( i think ) but on my paper i don't have enough information to do anything with?
yes, you need to do a free body diagram, and F = ma, twice, once for each mass
(i thought you'd already done it for the left hand mass)
(the left hand one should give you T, then you put that value of T into the right hand one, to find m)
what are your two F = ma equations?​
i didnt use f = ma for the left one. I thought that 20.58N * sin60 would give the force parallel to the slope
getting 17.83 and then 20.58 cos 60 = 10 . 29 N would the the normal force
so what... then i have ... Fnet = ma~
t1 + 20.58 + 10.29 = (2.1)(.64)
(all the forces?)
is that right? >.<? ( for the left )
(all the forces?)
ah, no …
you're fundamentally misunderstanding the vector nature of F = ma …
force and acceleration are both vectors, and F = ma is a vector equation …
that means you must choose a direction, and take components of F and of a in that direction
try it again, doing it in the direction of the slope :smile:
(btw, no need to call it T1, then two tensions are the same, so just call it T :wink:)
i don't understand what you mean.
the block is moving up the slope at .64 ms
its Fg is 9.8 * 2.1 right?
so i have a, and fg right there.
the normal force is the force the slope is pushing back up into the mass right?
moving in the x direction is Fg * cos 60 right? or Fg sin 60??
so why not plug it in from there?
T + fg + Fn = (2.1)(.64)
thanks for your help man, I am giving up.. dropping the class going to try again next semester
paace
great i can't drop this class because then ill lose my financial aid.
time to commit suicide
(just got up :zzz: …)
because you must use the components (along the slope), not the whole forces :redface:
there are three forces on the left hand mass:
the weight W, the normal force N, and the tension T
ok let's do this slowly and logically …
i] what is the component of W along the slope (up being +ve)?
ii] what is the component of N along the slope (up being +ve)?
iii] what is the component of T along the slope (up being +ve)? :smile:
just wanted to pop back in here and say thanks for the help, was just getting frustrated. ended up getting a decent grade in the class thanks to your help and others from this site.
never taking a calc based phys course during the summer again. I need more time to learn LOL
