What Happens When Mirrors Face Each Other?
  • Thread starter Thread starter Anonymous9001
    Mirrors
When two mirrors face each other, they create a series of reflections, but without a light source, they appear as if they are in darkness. To perceive light, photons must enter the eye and interact with retinal molecules, triggering the visual process. The discussion emphasizes that seeing involves absorbing multiple photons emitted or reflected from objects, rather than directly seeing a single photon. In a hypothetical scenario with two observers and one photon, the observer who absorbs the photon would perceive it, while the other would not. Ultimately, photons themselves do not have a visual appearance; they only facilitate the process of seeing.
Anonymous9001
If you place two mirrors directly on top of each other what exactly happens? My physics teacher says that it will create a perfectly black body?
Science news on Phys.org
Facing each other?
You get a lot of reflections (assuming a light source). If not, it's no different to anything else in the dark.
In order to see light, it mst travel through our eyes correct?
Yes, light needs to enter your eye in order for you to see.
What exactly do we see? Is the light we see just individual photons traveling from a source towards our eyes?
If so, say we set up an experiment where 1 photon is traveling through space past two observers. Also, say these observers were small enough to see the photon. Who would see it?
For you to see anything a photon (in reality MANY photons) must enter your eye, strike a specific molecule in your retina and cause that molecule to change shape. This sets off a chain of events that eventually causes your brain to "see" something.
You couldn't SEE a photon. The process of seeing involves absorbing photons that are emitted or reflected off of other objects and absorbed in your eye. Since nothing can bounce off of a photon, there isn't anything to see. It quite literally doesn't look like anything. :biggrin:
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
