Two wires, where is magentic field zero?
  • Thread starter Thread starter FuzzyDunlop
    Field Wires Zero
The discussion focuses on finding the point along the y-axis where the magnetic field is zero between two parallel wires carrying currents in opposite directions. The currents are I1 = 53 A and I2 = 37 A, positioned at y1 = 3 cm and y2 = 13 cm, respectively. The participant attempted to set the magnetic field strengths equal to each other to solve for the distance but encountered confusion regarding the direction of the magnetic fields produced by the currents. The calculation led to a position of r = 5.88 cm, but the participant recognized a potential error in understanding how the opposing currents affect the magnetic field vectors. The discussion highlights the need for clarity on the behavior of magnetic fields in such configurations.
FuzzyDunlop
Two wires carry current I1 = 53 A and I2 = 37 A in the opposite directions parallel to the x-axis at y1 = 3 cm and y2 = 13 cm. Where on the y-axis (in cm) is the magnetic field zero?
I1= 53 A
I2=37A
B(r)=Iu/[2(pi)r]
I thought i could solve this guy by setting the strengths of the fields equal to each other and finding r. Much of it would cancel out so I basically had
53u/(2[pi]r)=37u/(2[pi](10-r)
[(10-r)*53]/r=37
r=5.88
and then I added 3 to r since the starting position is y=3. It made sense to me but obviously i messed up somewhere.
If the current in the wires is going in opposite directions what do the field vectors do in the distance between the 2 wires?
