Is 70ps a Normal Propagation Delay for a 90nm Full Adder?
The discussion centers on the propagation delay of a full adder designed for a 16-bit ALU using a 90nm process. The user reports a propagation delay of 70ps for the AND operation, which is considered acceptable given the advancements in technology. Typical propagation delays for full adders in similar processes are in the range of hundreds of nanoseconds, with individual operations like AND and XOR generally taking around 40 to 50 nanoseconds in 45nm technology. Factors such as input capacitance and voltage levels significantly influence gate delays.
  • Understanding of digital circuit design
  • Familiarity with propagation delay concepts
  • Knowledge of SPICE simulation tools
  • Experience with semiconductor technology, specifically 90nm processes
  • Research propagation delay metrics in 90nm full adder designs
  • Learn about SPICE simulation techniques for digital circuits
  • Investigate the impact of input capacitance on gate delays
  • Explore voltage scaling effects in low voltage CMOS technology
Digital circuit designers, semiconductor engineers, and students studying VLSI design who are interested in propagation delays and performance optimization in modern technology nodes.
nmaganzini
Member warned to use the formatting template for homework posts.
Hi guys,
I was just wondering, I'm designing a full adder for a bitslice of a 16 bit ALU.
I have SPICED my design and I am getting a propagation delay for the AND mode between the two bits of about 70ps.
I'm working in a low voltage 90nm process.
Am I in the right ballpark in terms of propagation delay? or am I absurdly off? What is a typical propagation delay for a full adder (order of magnitude).
Thanks
If I recall correctly (it's been a while, so I might be off), the delay for the entire adder circuit is usually in hundreds of nanoseconds, and individual operations (AND and XOR) take about 40 to 50 nanoseconds each (with 45nm technology).
But as you might know already, gate delays depend on a number of factors such as the input capacitance, threshold and supply voltages etc. So there might be nothing wrong with the numbers that you have obtained.
45-50 nanoseconds for individual operations would surprise me. Even with an extremely long pipeline a CPU has to get those operations done within a cycle, and in 2008 they certainly had more than 20 MHz.
11K
13K
10K
