UltraCapacitor Charging Voltage
  • Thread starter Thread starter newman180
    Charging Voltage
Charging ultracapacitors with a 20V source is theoretically safe as long as the voltage does not exceed the maximum rating of 14V. The difference in voltage can influence the current transmitted, following Ohm's law. However, practical implementation requires careful current limitation to protect both the ultracaps and the power source. Using a properly sized resistor can achieve this, though it may reduce efficiency. A dimensional analysis is recommended to assess if the regenerative braking system can effectively reclaim enough energy to justify the additional components.
newman180
I am working with a hybrid car which charges a bank of ultracaps from regen braking.
I read an article which I believe was written by someone who is misinformed, but it had me thinking...
Just to clarify some theory about charging voltage,
Scenario
Max ultracap voltage= 14V
Current ultraCap Voltage= 10V
Motor BEMF Voltage = 20V
It is safe to charge the ultracaps with the 20V source until the caps are at 14V, correct?
Potentially, the greater the difference of voltage (potential) is related to how much current can be transmitted. V=IR
Sure. In theory it is safe to charge 14V capacitors with a 20V source as long as the charging is stopped before the capacitor reaches 14V.
In practice this is much harder that it might seem. The most important thing, as you mentioned, will be to limit the charge current. This protects both the capacitor and the power source. A properly sized resistor will do this.
It's not the most elegant solution and will cost efficiency for its simplicity so you might want to do a rough dimensional analysis to figure out if the regenerative breaking system you intend can reclaim enough energy to justify hauling around all the extra hardware.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
11K
