Uncertainty principle - light beam
The discussion centers on the behavior of a light beam when projected through a slit, particularly at a distance of 100 meters. It questions whether the beam would still spread out under these conditions and emphasizes that human consciousness does not influence the uncertainty principle. The conversation highlights the importance of the slit edges' imperfections, suggesting that ragged edges can affect the beam's projection. Additionally, it raises the question of why a physicist would not also reduce the height of the slit while decreasing its width. Overall, the dialogue explores the implications of slit geometry on light behavior and distortion.
Dav333
In regards to watching this video:
If the distance between the light source & board which the light is being displayed on was far apart like 100m. & you were the only person around observing the results right near the display. Then would the beam still be spread out?
Confused with this, thanks.
Science news on Phys.org
Human consciousness has nothing to do with the uncertainty principle.
What about the fact that the edges of the slit are vertical, and their imperfection (not smooth but ragged) becomes more and more important with respect to the width of the slot?
Why would not this “physicist” decrease the height of the slot too while the width diminishes?
My point is that in the case of a large slot the beam goes through undisturbed (round projection) and projected as a round.
With the unsymmetrical "type" of reduction of the slot (that is in the vertical direction only) horizontal distortion occurs due to the edges of the slot but not to the vertical direction (because no interaction occurs there).
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
