Understanding Bidimensional Movement: A Homework Guide
  • Thread starter Thread starter Jimmy84
    Movement
The discussion focuses on a homework problem involving a particle's bidimensional movement in the xy plane, requiring calculations of acceleration, motion type, and total displacement. The participant calculated the acceleration at t=4 seconds as 6.71 m/s² but struggled with graphing acceleration components versus time. Suggestions included plotting x and y components separately or creating a magnitude graph. The motion analysis indicates a complex trajectory involving loops and transitions across quadrants, but the participant finds it challenging to define the motion succinctly. Overall, the conversation highlights the difficulties in visualizing and articulating bidimensional motion concepts in physics.
Jimmy84
I have this homework due for tomorrow and I am a bit stressed about it I really would appreciate some help I don't understand the concepts involved.
A particle that in t = 0 is in the origin, moves in the xy plane with a velocity :
v=[(2.0m/s^2)t -(1.0m/s^3)t^2] x - [-2.0m/s]+(3.0m/s^2)t] y
-Calculate the aceleration at t=4 s . Draw the graph of a vs t
-What kind of motions does the particle has?
-If the particle lasted 10 s traveling what was its total displacement?
I already have the components of aceleration by derivating Vx and Vy
at t= 4s the aceleration i found was 6.71m/s squared
I have no clue about how to draw the graph of a vs t since a is given as unit vectors of x n y how can I plot it?
I would truly appreciate your time
Thanks in advance.
Please any help
You could plot the magnitude of the acceleration versus time.
You could plot the x and y components of the acceleration versus time separately (separate graphs).
You could produce a 3D plot with time on the Z-axis (probably a bit over the top for this sort of problem!).
thanks i ploted the ax n ay graphs
my first idea is to try to find the displament vector of y n x by integration. then to use it to describe the motion of the particle when it goes to the direction -x n -y
I know the questions are vague but that is how they were given.
I'm not sure how to answer a vague question like that. I can plot the motion and see it, but I'm not sure what would constitute a definitive answer as to "what kind of motion the particle has". Mathematically the x-component is a combination of square and cubic terms in t, while the y-component has linear and square terms in t. The result is a sort of quick loop in the first quadrant into the fourth quadrant, followed by a prolonged exit down and to the left in the third quadrant. I don't know of an elegant summarizing term for this shape.
thanks I appreciate it well that is what I have to deal with my physics teacher
