Understanding Gamma Function and Series Integration
  • Thread starter Thread starter H2instinct
    Integration Series
The discussion revolves around understanding the Gamma function and its properties, particularly in relation to series integration and proofs involving the Gamma function for half-integer values.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the relationship between the Gamma function and factorials, with attempts to prove specific properties of the Gamma function for half-integer values. Questions arise about the connection between different parts of the problem and the clarity of the proof process.
Some participants have provided insights and clarifications regarding the proof structure, while others express confusion about the connections between different parts of the problem. There is an ongoing exploration of the assumptions and definitions involved in the proofs.
Participants note the need to prove certain relationships and the importance of establishing a base case for induction. There is mention of separating parts of the problem for clarity, as well as the challenge of understanding the proof without complete solutions being provided.
H2instinct
Gamma(n+1) = n(gamma(n))
I have searched around trying to figure out how to do this. So far I have come out with:
Gamma(n) = (n-1)(n-2)...
Gamma(n+1)=n(n-1)(n-2)...2(1) otherwise known as Gamma(n+1)=n!
Problem is... I don't fully understand what I did because I followed a like example. Can someone please help me out with this. Also I have not even attempted the second part, so ignore that for now.
First part.
[tex]\Gamma(n+1) = n\Gamma(n)[/tex]
[tex]\Gamma(\frac{5}{2})=\Gamma(1+\frac{3}{2})=\frac{3}{2}\Gamma(1+\frac{1}{2})=\frac{3}{2}\frac{1}{2}\Gamma({\frac{1}{2})=\frac{3\sqrt{\pi}}{4}[/tex]
This part is for the proof.
Assume true for k
[tex]\Gamma(k+\frac{1}{2})=\frac{1.3.5...(2k-1)\sqrt{\pi}}{2^k}[/tex]
Then prove for k+1
[tex]\Gamma(k+1+\frac{1}{2})=(k+\frac{1}{2})\left(\frac{1.3.5...(2k-1)\sqrt{\pi}}{2^k}\right)[/tex]
Note the recursion relation, then,
[tex]\Gamma(k+1+\frac{1}{2})=\frac{1}{2}(2(k+1)-1)\frac{1.3.5...(2k-1)\sqrt{\pi}}{2^k}=\frac{1.3.5...(2k-1)(2(k+1)-1)\sqrt{\pi}}{2^{k+1}}[/tex]
Complete the proof by proving for k=1 and hence all positive integers.
A little confused because I think you combined both parts of that. Both of those have nothing to do with each other, but otherwise you helped me with the first one.
I just worked out the value of 5/2 for the first one, and for the second I used the relationship we worked out at the beginning and proof by induction to answer the last part of it. I've separated them now too.
Thank you for the help, but I still don't see the proof from (1.3.5...(2n-1))/2^n == (2n)!/((4^n)(n!))
It's fine. I'm going to move on and get help from a classmate when the time comes. Thanks for the help though!
I'll clarify:
The question asks you to prove that
[tex]\Gamma(n+\frac{1}{2}) = \frac{1.3.5.7...(2n-1)}{2^n}\sqrt{\pi}[/tex]
We can sort of see this in the 5/2 example, all the numerators are odd numbers and the denominator is always 2, so the odd numbers will multiply successively n-times on the top and 2 will be of the power n on the bottom, and always at the end is the square root of pi. To prove this first "assume" that it is true for any number say, k.
[tex]\Gamma(k+\frac{1}{2}) = \frac{1.3.5.7...(2k-1)}{2^k}\sqrt{\pi}[/tex]
We assume this is true, and now we try to prove it for k+1, we want the next odd number to appear on the numerator and for another 2 to be multiplied in the denominator (or half on the numerator) to make the right hand side look like this:
[tex]\frac{1.3.5.7...(2k-1)(2(k+1)-1)}{2^{k+1}}\sqrt{\pi}[/tex]
Once this happens all we have to do is show that the equation holds for n=1 and then we get it true for n=1,n=1+1 etc.
From the relationship we established,
[tex]\Gamma(n+1)=n\Gamma(n)[/tex]
We can add 1 quite nicely:
Remember that we have assumed that
[tex]\Gamma[k+\frac{1}{2}] = \frac{1.3.5.7...(2k-1)}{2^k}\sqrt{\pi}[/tex]
So for k+1:
[tex]\Gamma(k+1+\frac{1}{2}) = (k+\frac{1}{2})\Gamma(k+\frac{1}{2})[/tex]
(k+1/2 is n here.)
[tex]\Gamma(k+1+\frac{1}{2}) = (k+\frac{1}{2})\frac{1.3.5.7...(2k-1)}{2^k}\sqrt{\pi}[/tex]
Now all we need to do is rearrange it
[tex](k+\frac{1}{2})\frac{1.3.5.7...(2k-1)}{2^k}\sqrt{\pi} = \frac{1}{2}(2k+1)\frac{1.3.5.7...(2k-1)}{2^k}\sqrt{\pi}[/tex]
Notice that we have a half and a 2k+1, which if you look is actually (2(k+1)-1), our next odd number.
[tex]\frac{1}{2}(2k+1)\frac{1.3.5.7...(2k-1)}{2^k}\sqrt{\pi} = \frac{1.3.5.7...(2k-1)(2(k+1)-1)}{2^{k+1}}\sqrt{\pi}[/tex]
So if it's true for k it is true for k+1, if you prove it for k=1 you have proved it then for all positive n.
[tex]\Gamma(1+\frac{1}{2}) = \frac{\sqrt{\pi}}{2} = \frac{1.\sqrt{\pi}}{2^1}[/tex]
[tex]\Rightarrow \Gamma(n+\frac{1}{2}) = \frac{1.3.5.7...(2n-1)}{2^n}\sqrt{\pi}[/tex]
For positive n.
Edit: The final part of the proof would just be manipulating the expression to match the RHS.
Thanks, I understood it much better from that.
  • · Replies 17 ·
