Kirchoff's Law is applicable in AC circuits when using impedance and reactance. The relationship is defined by the equation V=I|Z|, where Z is the total impedance calculated as |Z|=√(R²+χ²). The reactance χ is the difference between inductive and capacitive reactance, represented as χ=χ_L-χ_C, with χ_L and χ_C defined by their respective formulas. For accurate analysis, voltages and currents should be expressed in complex form, ensuring all values are at the same frequency. This approach allows for effective application of Kirchoff's Law in AC circuit analysis.
#1
prasanaharani
Whether Kirchoff's Law Is Applicable In A/c.then Say How?
#3
ice109
1,707
using impedance/reactance
V=I|Z|
where Z is
|Z|=\sqrt{R^2+ \chi ^2}
where \chi is
\chi = \chi _L - \chi _C
where \chi _L and \chi _C are
\chi _L=2 \pi f L and \chi _c= \frac{1}{2 \pi f C}
note: these equations only give you maximum or rms voltage or current
for instantaneous use these, which if you don't know, are sinusoidal functions
\tilde{V} = V_0e^{i(\omega t + \phi_V)}
and
\tilde{I} = I_0e^{i(\omega t + \phi_I)}
\omega = 2 \pi f and tan( \phi ) = \frac{ \chi}{R}
ranger
It is very much applicable. The catch is that you should have them in complex form (phase and magnitude) and all listed currents and voltage must be of the same frequency.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable?
For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them.
My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
