Understanding Pressure Losses and Calculation Methods
  • Thread starter Thread starter physea
    Pressure
Darcy losses refer to pressure losses that are primarily associated with static pressure rather than dynamic or total pressure. Pressure losses in fittings, such as bends, also relate to static pressure. Static pressure can be calculated based on the hydrostatic pressure of the fluid in the system, and it represents the pressure of a non-moving fluid or the pressure measured while moving with the fluid. Dynamic pressure remains constant along a pipe, indicating that Darcy losses reflect changes in static pressure. There is no singular equation for static pressure, as it is often provided rather than calculated.
physea
Hello,
The Darcy losses are pressure losses in the dynamic, static or total pressure?
Also, the pressure losses in various fittings (eg. bends) are they dynamic, static or total pressure?
Also, how can we calculate the static pressure? Is it the hydrostatic pressure of the amount of water flowing in the pipe? What is it exactly?
Thanks!
Read the Wikipedia article very carefully. Then get a copy of Crane Technical Paper N. 410: Flow of Fluids Through Valves, Fittings, and Pipe. You can find it free online. TP 410 is a standard reference for anybody interested in fluid flow.
Likes berkeman
What do you know about dynamic pressure? Specifically, along a constant diameter pipe, is the velocity pressure the same, higher or lower at the end than the beginning?
Static pressure is pressure of a non-moving fluid or if your fluid is moving, it is pressure measured when moving with the fluid. Calculating it depends on the situation.
Likes berkeman
I am not sure we no one replies clearly and you prefer setting riddles.
Dynamic/velocity pressure stays constant, so Darcy losses represent static pressure only? In case the diame
What is the equation for static pressure?
It's because forcing y ou to think is a surer way to make you understand than spoon feeding you the answer.
Correct!
There is no one equation for static pressure. It's usually a given, not a calculation.
