Understanding telescoping series
jinksys
I understand that if given the following series:
\sum _{n=1}^{\infty } \frac{1}{n(n+3)}
I can break it up using partial fraction decomposition into:
\sum _{n=1}^{\infty } \frac{1}{3n}-\frac{1}{3n+9}
If I start listing the values of n_1,n_2, etc, I can see the cancellation pattern and find the sum.
This process seems tedious, is there another way of doing these problems?
Wikipedia says:
* Let k be a positive integer. Then
\sum^\infty_{n=1} {\frac{1}{n(n+k)}} = \frac{H_k}{k}
where Hk is the kth harmonic number. All of the terms after 1/(k − 1) cancel.
But I'm not sure what the 1/(k - 1) means, nor do I understand the harmonic number bit either.
I think that what you are doing is correct, and probably the intended method to use. Sometimes you just got to go ahead and brute force your way through it.
Ok,
Do you know what my wikipedia snippet is referring to?
http://en.wikipedia.org/wiki/Telescoping_series
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
