Understanding the Bode Plot: Frequency vs. dB
The discussion focuses on the axes of a Bode plot, clarifying that the x-axis can represent either angular frequency (omega) or frequency (f), while the y-axis is expressed in decibels (dB) using the formula 20 log(|H(jw)|). A user seeks guidance on setting specific ranges for the axes in a Nyquist plot, detailing a transfer function for context. Another participant advises starting a new thread for unrelated questions to maintain clarity. The conversation highlights the importance of proper axis representation in frequency response plots and the need for organized forum discussions.
math&science
Is the x-axis of a Bode plot supposed to be angular frequency omega or just the frequency f? The y-axis is in dB. Thanks!
Usually when I draw it on paper, I have it in angular frequency [rads/sec] (log scaled). The y-axis is 20 log (|H(jw)|) [dB].
hi, i would like know how to set the range on the axis? for an example i want to plot a nyquist plot with the range of x-axis is from -0.08 to 0.02 and the range of y-axis is from -0.2 to 0.2. (with the system G =(5s + 200)/((s)*(s^2 +4s + 10)*(s^2 + 10s + 150))...
please help me out here if anyone knows how to write in the m.file(MATLAB)...thanks
Welcome to PhysicsForums! For future reference, whenever you have something like this (a somewhat related question that nevertheless does not directly follow from the previous items) you really ought to start a new thread, not resurrect one that's 4 years old!
In any case, take a look in this thread:
https://www.physicsforums.com/showthread.php?t=303967
(Second mention in less than 3 hours!)
sorry about that :)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
