Understanding the Spacetime Interval and the Condition for Simultaneity
The spacetime interval \( s \) between two events is defined by the equation \( s^2 = c^2 t^2 - x^2 \), where \( t \) is the time interval and \( x \) is the spatial distance. For two events to be non-simultaneous in all frames, the condition is \( s^2 > 0 \), indicating that the time interval \( |t| \) exceeds the distance \( |x/c| \). Conversely, if \( s^2 < 0 \), a frame exists where the events can be simultaneous, while \( s^2 = 0 \) implies that the events occur at the same location in space. Understanding these conditions is crucial for grasping the implications of relativity.
  • Understanding of spacetime concepts in special relativity
  • Familiarity with the equation of the spacetime interval
  • Knowledge of inertial frames and their transformations
  • Basic grasp of the speed of light as a constant (c)
  • Study the implications of the Lorentz transformation on spacetime intervals
  • Explore the concept of light cones and their relation to simultaneity
  • Learn about the physical interpretation of spacetime intervals in relativistic physics
  • Investigate scenarios involving time dilation and length contraction
Students and professionals in physics, particularly those studying special relativity, as well as educators seeking to clarify concepts related to spacetime and simultaneity.
theneedtoknow
The spacetime interval s between two events is s^2 = c^2*t^2 - x^2 where t is the time between the 2 events and x is the distance between the 2 events in a given frame of reference.
What is the general condition on s such that two events cannot be simultaneous in any
frame?
I don't really understand the question..
What am i supposed to do?
I mean...the shortest possible time between 2 events is 0, so picking a reference frame in which they are simultaneous, the spacetime interval between them would simply be the distance x between them
or
s = root (-x^2)
which is not a real number...(even though I think the spacetie interval can be imaginary)
So if the time between any 2 events is more than 0, then the spacetime interval would be greater than root (-x^2) since we'd be substracting -x^2 from a number larger than zero...so is the restriction that if s is less than root (-x^2), then 2 events can' tbe simultaneous in any frame?
Can someone please tell me if I am on the right track at all??
Does this make sense?
The spacetime interval between two events doesn't change when you change from one inertial frame to another, although x and t do. If s^2 = 0, the measured time between events (t) is equal to the time required for light to travel the measured distance between the events (x/c). So only if x=0 could the events be simultaneous.
If s^2 < 0, the measured time between events is less than the time required for light to travel the measured distance between events; so a frame can be found in which the events are simultaneous. In this frame x^2 = -s^2.
If s^2 > 0 , |t| > |x/c|. Since the distance between the events can't be negative in any frame, t must be greater than 0. There is no frame in which the events are simultaneous.
  • · Replies 28 ·
  • · Replies 21 ·
