Uniform acceleration of rolling cart
The lab involved rolling a cart down a ramp with a tickertape to measure time intervals of 0.10 seconds, leading to the creation of distance-time, average velocity-time, and acceleration-time graphs. The distance-time graph showed a curve, indicating non-uniform motion, while the average velocity was calculated using displacement differences over time intervals. Instantaneous velocities, determined by drawing tangents on the distance-time graph, were found to be slightly higher than average velocities, raising questions about their relationship. The average velocity-time graph did not pass through zero due to the initial velocity at the start of the measurement interval. Additionally, the calculated acceleration of 6.5 m/s^2, lower than the expected 9.8 m/s^2, could be attributed to experimental errors such as friction or measurement inaccuracies.
jnimagine
We did a lab, where a cart was rolled down a ramp and a tickertape was attached to the cart as it rolled down. When the cart finished the course of rolling down, a line was drawn across the tape through every sixth dot to show that it is an interval of 0.10s.
Then we had to make 3 graphs: distance - time, average velocity - time, and acceleration - time.
When the displacement was graphed, the graph was a curve. The average velocity was calculated by subtracting the displacement at 0.10s from the displacement of 0.20s then dividing it by 0.10s.
When tangents were drawn on the distance time graph and slopes calculated to find out the instantaneous velocity, the slopes were slightly larger than all the average velocities. It said that the average and the instantaneous velocity must be the same. Why is that?? and what could explain the differences between the two in my result?
Also, what are some reasons why the average velocity - time graph does not pass through zero?
When the average velocity was graphed and a line of best fit was drawn, the slope was caculated to figure out the acceleration. This acceleration was only 6.5m/s^2 instead of 9.8m/s^2. What could be some errors in the lab (not human errors) that could have caused this problem??
If anyone could suggest some explanations to my questions, I would greatly appreciate it. Thank you. :)
Easy question first, why the graph does not pass through zero. it does not pass through zero because you started with a velocity interval between t=0s and t=.1s. The smaller that time interval, the closer you would get to a starting velocity of zero. You could have also held the cart at the top for a few points, then dlet it go. That would get you a line that started at zero then increased.
I do not know offhand why the average and instantaneous velocities would ever be the same in this case. At certain points, with smartly chosen averages you might be able to have them be the same. Also if you took your average speed across a smaller time you would get closer to the instantaneous velocity.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
