Uniform Circular Motion A Jet Pilot
A jet pilot is analyzing the minimum radius of a vertical loop for his aircraft, ensuring that the centripetal acceleration does not exceed 6.0 g's while flying at a speed of 840 km/h. The pilot converts the speed to 233.33 m/s and calculates the maximum allowable acceleration as 58.8 m/s^2. Using the formula for centripetal acceleration, a = v^2/r, the pilot derives two potential radii: 925.90 m and 14.82 m. The first calculation of 925.90 m is confirmed as correct, while the second is deemed incorrect due to a misunderstanding of the variables. The discussion emphasizes the importance of correctly identifying velocity and acceleration units in physics problems.
Brenwells
Uniform Circular Motion "A Jet Pilot"
Hi, my apologies if this has been posted before. I was just wondering if someone could help look over this question for me and confirm if I did it correct or not. It is a written homework rather than online so I can't check my answer to see if I did it correctly.
A jet pilot takes his aircraft in a vertical loop. (a) If the jet is moving at a speed of 840km/h at the lowest point of the loop, determine the minimum radius of the circle so that the centripetal acceleration at the lowest point does not exceed 6.0 g's.
840km/h = 233.33 m/s
6g = (6*9.80) = 58.8m/s^2
Equation used a=(v^2)/r
but I continue to get confused between which is velocity and acceleration.
Would I have
r=(233.33^2)/58.8
r=925.90m
or
r=(58.8^2)/233.33
r=14.82m
which the first answer of 925.90m sounds a lot more correct than 14.82 but I just wanted to make sure. If someone could please confirm that would be great.
Thank you
Velocity has units of m/s
Acceleration has units of m/s^2
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
