Uniform Circular Motion and Centripetal Force
The discussion revolves around a physics problem related to uniform circular motion and centripetal force, specifically concerning the safe speeds for vehicles on a banked curve. The problem involves parameters such as the radius of the curve, the angle of banking, and the coefficient of static friction.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • The original poster attempts to analyze the forces acting on a vehicle navigating a banked curve, including gravity, normal force, and friction. They express confusion about the correct application of these forces and the resulting calculations. Other participants question the original poster's understanding of the forces involved, particularly regarding the direction of friction and the need for a correct free-body diagram.
Participants are actively engaging in clarifying concepts related to the problem. Some guidance has been offered regarding the correct interpretation of forces and the role of friction, but the discussion remains open with no consensus on the correct approach or solution yet.
The original poster indicates a potential misunderstanding in their force analysis and the setup of their free-body diagram, which may be affecting their calculations. There is an ongoing exploration of the assumptions regarding the direction of friction in the context of circular motion.
AJayS
Hey guys, first post here! Hoping to get a little help.
You are a traffic safety engineer in charge of determining safe speeds for roads. A particular banked curve has a radius of 11.0 meters and is banked at an angle of 8.00°. The coefficient of static friction between common tires and this road is 0.870. What is the maximum speed that a car can drive this curve? Use both the bank of the curve and the friction on the tires in determining your answer.
f=μn
Fc=mv^2/r
So what I did was split the force of gravity, mgcos8 in the direction perpendicular to the ramp and mgsin8 parallel. Also, the force of friction towards the center of rotation and set all forces towards the center of rotation to mv^2/r.
Essentially, I had mgsin8 + (μ X mg X cos8)=mv^2/r.
Common factor of m cancels and I solve for V as everything else is given. I receive an answer of 10.4 m/s. The correct answer is apparently 11.1 m/s, so close, but not close enough for a rounding issue I believe. My only other guess is that somehow I've split the vector wrong. Any help's much appreciated, thanks very much in advance.
Welcome to PF;
Notice that gravity acts straight down - so there is no component of the gravity force acting directly towards the center of the turn.
Did you draw a free-body diagram?
You need the vector sum of the forces to point horizontally towards the center - the forces are gravity, friction and the normal force from the road and they all act in different directions.
Hi Simon, thanks for the response.
Now I see it a little clearer. I did draw a free body diagram but it was incorrect. I was treating the parallel surface of the bank as straight horizontal. I'm still getting an incorrect answer however.
As I have it, I have the sum of the horizontal forces as the normal force in the x direction (Fnsin8). I am confused as to where friction fits into all of this. If I'm correct, doesn't friction always oppose the direction of motion? In other words, would the ∑Fx= Fnx - friction in the x direction?
Nope - a car accelerating forward in a straight line has a net friction force acting on it pointing in the same direction as the acceleration.
In this case, this is static friction. Static friction acts one stationary objects too - more accurately: between surfaces that are instantaneously stationary wrt each other.
It opposes the direction the surfaces would move if there were no friction.
Consider:
http://t0.gstatic.com/images?q=tbn:ANd9GcSfjwcftYv3-4OgKxziSLn1cHg850F5nLClXo9lngoNk7IXNoqNvQ
  • · Replies 18 ·
  • · Replies 28 ·
