Uniform Circular Motion of a satellite
To solve the satellite problem, the radius of the orbit must include both the Earth's radius and the altitude of 640 km, and the period of 98 minutes should be converted to seconds. The speed can be calculated using the formula for circular motion, where the satellite completes a full circumference in one period. For the stone whirled in a circle, the centripetal acceleration can be determined by first calculating the time it takes to fall to the ground after the string breaks. Understanding projectile motion is essential to find the speed of the stone before it was released.
DramatikaRocks
Problem:
I have these exercises that I need help with. They look easy and I have an idea on what to do, but the answer I get is not right. I know I'm doing something wrong and I need any help I can get.
1.) An Earth satellite moves in a circular orbit 640 Km above Earth's surface witha period of 98.0 min. What are the a.) Speed and b.) the magnitude of centripetal aceleration of the satellite?
I want to know what is the radius that I use and if I have to change 98 min for seconds?
If I have the speed I can calculate the aceleration.
The problem is I'm assuming that the radius is 640km and I divide that with 98.0 min but that is not the right answer.
the other exercise is :
1.) A boy whorles a stone in an horizontal circle of radius 1.5m and at a height of 2.0m above level ground. The string breaks,the stone flies off horizontally and strikes the ground after traveling a horizontal distance of 10m. What is the magnitude off the
centripetal aceleration of the stone while in circular motion?
2.) The question is that I need the speed and I have no Idea how to get it. And I don't know how to solve this really.
You need the radius of the satellite's circular orbit. 640 km is just the distance above the earth--be sure to include the radius of the earth. Convert distance to meters and time to seconds. Realize that the satellite travels a complete circumference in every period.
You'll need to use your knowledge of projectile motion. How long does it take for the stone to fall? Use that to figure out what its speed must have been.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
