Uniform Circular Motion question
In a scenario involving a 1,320-kg car traveling at 34.0 m/s, the maximum horizontal force exerted by the pavement is 6,300 N. To avoid a collision with a wall while braking, the minimum distance required is calculated to be 121.17 meters. When maintaining constant speed and turning, the centripetal force needed for the turn is provided by friction, leading to a minimum turning radius of 242.2 meters. The calculations confirm that the approach to both braking and turning is correct. Understanding these principles of uniform circular motion is essential for safe driving maneuvers.
devilish_wit
While learning to drive, you are in a 1 320-kg car moving at 34.0 m/s across a large, vacant, level parking lot. Suddenly you realize you are heading straight toward a brick sidewall of a large supermarket and are in danger of running into it. The pavement can exert a maximum horizontal force of 6 300 N on the car.
(1) Suppose you apply the brakes and do not turn the steering wheel. Find the minimum distance you must be from the wall to avoid a collision.
(2) If you do not brake but instead maintain constant speed and turn the steering wheel, what is the minimum distance you must be from the wall to avoid a collision?
F = ma
a = V^2 / r
m = 1320 kg
v = 34 m/s
F = 6300 N
(1) F = ma
6300 N = 1320kg a ---> a = 6300 N/1320kg = 4.77 m/s^2
Vf^2 = Vi^2 x 2ad
0 = (34 m/s)^2 + (2)(4.77)d
(34m/s)^2 / 2(4.77m/s^2) = d ---> d = 121.17m (This answer is correct)
(2) a = v^2 / r...
I'm not sure how to answer this second question and where to start. Any ideas?
Member advised not to provide complete solutions to other's homework
Hi,
We know that the mass is 1320 kg
maximum force by pavement of car is 6300N
thus maximum retardation that we can produce is = F/m= 4.77 m/s^2
using v^2=u^2 + 2as with appropriate signs we get
34^2=2⋅(4.77).s
thus s=121.17 meters for the second part let's say that while turning you're following a circular trajectory with constant speed hence it is a classical case of uniform circular motion
the centripetal force which is provided by the friction, since that is due to rubbing between the two surfaces i must say that the pavement is " kind of providing" the "turning force" which means 6300=mv^2/R where R is the radius of circular trajectory and also the minimum distance for turning if we consider length of car negligible
thus 6300=1320.(34)^2/r or R= 1320.(34)^2/6300=242.2 meters
i hope you understood my solution, i may be wrong too all suggestions are accepted. thank you
Likes devilish_wit
physics_pi_rate said:
Hi,
34^2=2⋅(4.77).s
thus s=121.17 metersfor the second part let's say that while turning you're following a circular trajectory with constant speed hence it is a classical case of uniform circular motion
Yes it's correct! :)
I am glad i could be of help to you :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
