Uniform Circular Motion and the Force of a Car on a Bumpy Road
A car weighing 1000 N travels over a bumpy circular road with a radius of 100 meters. At point A, the valley, the normal force is affected by both the car's weight and the centripetal force required for circular motion. At point B, the top of the hill, the normal force is less because the weight of the car contributes to the centripetal force. The discussion concludes that the magnitude of the force of the car on the road is larger at point A than at point B. Understanding the dynamics of forces at different points in circular motion is crucial for solving such problems.
nahanksh
A car, which weighs 1000 N, travels over a bumpy road with a constant speed. Gravity acts. The road at point B is in the shape of a circle with a radius of 100 meters.
http://online.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?courses/phys211/oldexams/exam1/sp08/fig21.gif
Which one of these statements correctly relates the force of the car on the road at points A (a valley) and B (the top of a hill)?
(a) The magnitude of the force of the car on the road is larger at point A than it is at point B.
(b) The magnitude of the force of the car on the road is larger at point B than it is at point A.
(c) You need to know the road radius at point A to answer this question.
a = v^2/r^2 = w^2*r
I thought at the point A, it's considered as the lowest point of circular path, while
the point B is considered as the highest point.
So, at A Weight is somewhat canceled with the tension(thinking about uniform circular path) but at B weight is added to the tension..
That's why i thought B has larger force than at point A...
What's wrong in my attempt..?
Please help me out here...
Thanks.
At point B, the centripetal force equation is
F_c= mg-N_B
where N is the normal reaction. What is the equation at A?
Isn't it F= (N)a - mg at A?
But I'm still confused it seems to me that normal force is the same for both points...
It's not the same, is it?
Thanks for your reply.
So at A, NA= mv2/r +mg
and at B, NB=mg-mv2/r
which one will be bigger?
Thanks a lot.
I've got it !
