- 10,498
- 1,644
Let's try the super-simple version. People usually mean the Rindler metric when they talk about a uniform gravitational field. If you mean something else, it's up to you to describe what you mean exactly.
The mathematical techniques usually used to describe a gravitational field are the associated metric. Give the metric, one requires that the metric satisfy Einstein's field equations. So if one wants to use some other notion of what a "uniform gravitational field" might be, other than the Rindler metric, one should write down the metric to communicate what this idea is.
This presuposes that one knows what a metric is. The situation if one doesn't know what a metric is problematic. The problem becomes - how does one verify that the proposed idea of a "uniform gravitaitonal field" is actually consistent with Einstein's field equations? WIthout the proper tools, one can't really answer this question.
The problem of time dilation on the Earth is interesting as well, but of course the gravitational field of the Earth isn't uniform field - loosely speaking, one might say it gets weaker as you get further away from the center of the Earth. It's perfectly valid though to find the appropriate time dilations for this case, using the Schwarzschild metric, and to explore the limit of what happens when the distances are short enough that the deviations from the field are almost uniform.
The basic answer for what happens when one takes the limit has already been hinted at (1+gh)(1-gh) = 1 - (gh)^2, and to linear order (gh)^2 = 0. So to linear order the "time dilations" are reciprocal. So things work out to linear order when one uses approximations valid to the linear order.
