Solving for Projectile Motion: Initial Velocity, Angle, Time, and Distance
  • Thread starter poohead
  • Tags
    Motion
In summary, the problem involves a body being projected upward from level ground at an angle of 50 degrees with an initial speed of 40 m/s. The questions asked are: A) How long before it hits the ground? B) How far from the starting point will it strike? C) At what angle with the horizontal will it strike? The relevant equations and a free body diagram are needed to solve this problem.
poohead
34
A body is projected upward from the level ground at an angle 50 degrees with the horizontal has an initial speed of 40 m/s.
A) how long will it be before it hits the ground?
B) How far from the starting point will it strike??
C) At what angle with the horizontal will it strike??
fatal
please help
PH, you probably need to put a bit more into this problem before asking for help. Surely you can come up with the relevant equations, or at least take a stab at them. Try drawing a free body diagram, and then write the equations of motion for the body.
1. What is projectile motion?
Projectile motion is the motion of an object that is projected into the air and then moves under the influence of gravity alone.
2. How do I solve for initial velocity in projectile motion?
To solve for initial velocity, you need to know the angle of projection, the time of flight, and the distance traveled. You can then use the equations of projectile motion to solve for the initial velocity.
3. Can I use any angle of projection to solve for projectile motion?
No, the angle of projection must be between 0 and 90 degrees. An angle of 0 degrees would result in the projectile not moving at all, while an angle of 90 degrees would result in the projectile moving straight up and then falling straight down.
4. How do I find the time of flight in projectile motion?
The time of flight can be found by using the equation t = 2 * (V * sin(A)) / g, where V is the initial velocity, A is the angle of projection, and g is the acceleration due to gravity (9.8 m/s^2).
5. What is the relationship between initial velocity, angle, time, and distance in projectile motion?
The initial velocity, angle, time, and distance are all related in projectile motion through the equations of motion. By knowing any three of these variables, you can solve for the fourth using the appropriate equation.
  • Classical Physics
