Union of subspaces of a linear space
de_brook
Is there a linear space V in which the union of any subspaces of V is a subspace except the trivial subspaces V and {0}? pls help
A vector space V can only have non-trivial subspaces if \dim V\ge 2.
This means you can choose two linearly independent vectors u, w, which generate 1-dimensional subspaces U, W respectively. Can U\cup W be a subspace? Hint: try to find a linear combination of u,w that is not in U\cup W.
I have tried searching for such spaces but i could only find for spaces whose dimension is less than 2.
\dim\mathbb{R}^n=n, surely you knew that?
yyat; Do you mean i can obtain a linear subspace V of \mathbb{R}^n such that the union of any subspaces of V is a subspace of V?
yyat; Do you mean i can obtain a linear subspace V of \mathbb{R}^n, such that the union of any subspaces of V is a subspace of V?
I think the short answer is No.
what about if you are not working n dimensional space, can you still find such a space
what about if you are not working with n-dimensional space, can you still find such a space?
If the dimension of the space is less than two then the only subspace are V and {0} as yyat pointed out. Hence your question is answered in this case.
If the dimension of the space is greater or equal to two then consider spaces X and Y generated by linearly independent vectors x and y. x+y does not belong to X \Cup Y. Implying you can't pick any subspaces and the union will be a subspace.
thanks so much.
