How Many Trucks Can US Oil Production Fuel in a Year?
The discussion revolves around calculating how many trucks can be fueled by US oil production, given that one truck consumes 6,000 barrels of oil annually. By dividing the total US oil production of 1.9 x 10^10 barrels by the annual consumption per truck, the result is 3,000,000 trucks. Participants clarify that while the initial calculation yields trucks per year, it can also be interpreted as the total number of trucks that can be fueled for a year. The conversation emphasizes understanding unit conversions and interpretations in the context of the problem. Ultimately, the calculation demonstrates that the US produces enough oil to fuel 3 million trucks annually.
cytochrome
If one truck runs on 6000 barrels of oil per year, how many trucks could run on the oil produced in the US in one year (1.9*10^10 barrels)?
(6000 barrels/year) used by one truck
(1.9*10^10 barrels/year) for US production
I simply divided 1.9*10^10 by 6000 to get 3,000,000.
I'm confused about the fact that 3,000,000 is not in units of "trucks". How can I set up this problem properly to include trucks as my units?
Hello cytochrome,
\left(\frac{1.9 \times 10^{10}~\textrm{barrels}}{1~\textrm{year}}\right) \cdot \left(\frac{1~\textrm{truck}}{6000~\textrm{barrels}}\right)
The unit of barrels cancels, leaving trucks and years, so your result is in trucks/year ("trucks per year").
EDIT: ACTUALLY, you can consider the quantity of 6000 to have units of "barrels per truck, per year" which would be barrels/(trucks*years). So, in that case, there would be 1 year in the numerator of the righthand factor in parentheses, and the year unit would cancel as well, leaving only trucks.
However, the way I did it is fine too. In this case, the way to think about it is that a "truck" is a unit of volume equal to the amount of oil needed to run one truck for a year. So, what your unit conversion is doing is saying that the US produces 3,000,000 "trucks" worth of oil per year. It's just a matter of interpretation.
Another version:
6000 bbl per year per truck
1.9 x 1010 bbl per year
Chestermiller said:
Another version:
Yup. I had edited my post to include this version (just not LaTeXed).
