Is there a unit for measuring electromagnetic force and what symbol denotes it?
The unit for measuring electromagnetic force is the Newton (N), similar to gravitational force. The force from an electric field is proportional to charge, making Newtons per coulomb or Volts per meter suitable for expressing field strength. This parallels gravitational field strength, which is measured in Newtons per kilogram or meters per second squared. The discussion emphasizes that force is universally measured in Newtons, regardless of its source. Understanding these units is crucial for comprehending electromagnetic interactions.
Einstein's Cat
In the same sense that Newtons (N) are the unit for measuring gravitational force, is there a unit for measuring electromagnetic force and if so what is it and what symbol denotes it? Thank you for your help and time!
Force is force. The Newton is an appropriate unit regardless of whether the force is from gravity or any other source.
The force from an electric field is proportional to charge. This means that an appropriate unit for expressing field strength is Newtons per coulomb or equivalently, Volts per meter.
This is analogous to the way in which gravitational field strength is measured. Those units are Newton's per kilogram or equivalently (because the kilograms cancel out), meters per second squared.
hi there
https://en.wikipedia.org/wiki/Electric_field
cheers
Dave
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
