C/C++ What is the proper way to write a unit test for addInventory() in C++?
The discussion revolves around writing a unit test for the `addInventory()` method in a C++ class. The main objective is to ensure that the method correctly updates the inventory quantity based on the input parameter. The user has successfully implemented the `addInventory()` function but is struggling with the unit test that verifies its functionality. The expected output for a failed test case is specified, where if the quantity does not match the expected value after adding inventory, a specific failure message should be printed. The user is advised to implement a check after calling `addInventory()` to compare the updated quantity with the expected value. If the check fails, the required error message should be displayed. Additionally, there is a suggestion regarding the use of a unit testing framework to simplify the testing process, allowing the user to focus on determining the necessary tests rather than the mechanics of test creation. The user acknowledges the need for conditional statements to implement the required checks effectively.
Teh
I got one correct for my code...what i am missing...any tips or guide?
Write a unit test for addInventory(). Call redSweater.addInventory() with parameter sweaterShipment. Print the shown error if the subsequent quantity is incorrect. Sample output for failed unit test given initial quantity is 10 and sweaterShipment is 50:
Beginning tests.
UNIT TEST FAILED: addInventory()
Tests complete.
Note: UNIT TEST FAILED is preceded by 3 spaces.
Code:
#include <iostream>
using namespace std;
class InventoryTag {
public:
   InventoryTag();
   int getQuantityRemaining() const;
   void addInventory(int numItems);
private:
   int quantityRemaining;
InventoryTag::InventoryTag() {
    quantityRemaining = 0;
int InventoryTag::getQuantityRemaining() const {
   return quantityRemaining;
void InventoryTag::addInventory(int numItems) {
   if (numItems > 10) {
      quantityRemaining = quantityRemaining + numItems;
int main() {
   InventoryTag redSweater;
   int sweaterShipment = 0;
   int sweaterInventoryBefore = 0;
   sweaterInventoryBefore = redSweater.getQuantityRemaining();
   sweaterShipment = 25;
   cout << "Beginning tests." << endl;
   // FIXME add unit test for addInventory
   /* Your solution goes here  */
   addInventory()
   redSweater.addInventory(sweaterShipment);
   cout << "Tests complete." << endl;
   return 0;
Inventory is 0, shipment is 25. Testing that quantityRemaining was updated to 25.
Your value: 25
Testing with sweaterShipment of 25. addInventory updates quantityRemaining.
Your output: Beginning tests.
Tests complete.
Inventory is 25, shipment is 5. Testing that quantityRemaining remains 25.
Your value: 25
✖ Testing sweaterShipment of 5. addInventory does not update quantityRemaining.
Expected output: Beginning tests.
Tests complete.
Tests complete.
Technology news on Phys.org
Beginning tests.
Tests complete.
You need to write code to add the amount of inventory specified, which you have done. Now you just need to check if you get the expected quantity after adding the inventory. If the check fails print the message they've asked for. I'm just not sure how the values they've provided as a sample would actually fail.
On another note if your being asked to do unit testing, why are they not having you use a unit testing framework to make the process of creating the tests easier so you can focus on the important part of unit testing which is determining which tests you require.
thanks for the help I needed to use if and else statement thanks!
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
