How do I calculate electricity usage in units?
  • Thread starter Thread starter Gringo123
    Electricity Units
To calculate electricity usage, multiply the power rating of the appliance in kilowatts (kW) by the time it is used in hours. For example, a 2.5 kW appliance used for 8 hours consumes 20 kWh (2.5 kW * 8 hours). Electricity is measured in kilowatt-hours (kWh), which represents the energy consumed over time. This measurement simplifies understanding energy usage compared to using joules directly. The discussion clarifies the relationship between power, time, and energy consumption, making it easier for beginners to grasp.
Gringo123
How can I work out how many units of electricty are consumed in problems such as the following?
During one day, a 2.5 kW appliance was used for 8 hours. How many Units of electricity were used?
I know that the answer is 20 but I have no idea how that figure is arrived at. Also, in what unit is the electricity measured. What exactly does "20 units of electricy" mean?
Thanks a lot
kW is a measure of power = the rate of energy used (kW = 1000J/s)
Electricity is sold in units of kWh = one kilowatt for one hour ( = 1000J/s * 3600s = 3,600,000J )
So a 2.5 kW appliance used for 8 hours = 2.5kW * 8h = 20kWh
Thanks a lot for your help.
So a 2.5 kW appliance means an appliance that consumes 2.5kW of energy if it runs for 1hour, is that right? Sorry, I'm a real beginner!
Not quite, 2.5kW is a unit of power, it is using 2.5 kJ (2500J) of energy per second.
So after one hour it has used = 2500 J/s * 3600s = 9MJ = 2.5kWh of electricity.
It's a bit strange using power (which is energy/time) multiplied by time to get back to energy - but Joules gives large numbers and kW and hours are more convenient for everday use it's easier.
It's a bit like if we measured distance by having a unit of car speed (mph) and instead of saying it was 30miles to town we said it was 30mph-hours. So after one hour at 30mph you have gone 30 miles.
Thanks a lot for that! It's a lot clearer now.
