CarpeCaelum said:
... how can galaxies have recession speeds of greater then 2c, since in my understanding c is the absolute speed limit?
Simple. c is just NOT an absolute speed limit
it is a speed limit that applies in very special situations
where special relativity applies
most galaxies are receding at speeds greater than c
the socall speed limit does not apply in general situations
where general relativity applies
we deal with this over and over at Cosmology forum and various people have various words they say to help make it all right (Pervect, SpaceTiger, Wallace, George Jones, Chronos they would all say slightly different words to help cushion the shock and help you assimilate).
I don't know what words are best to say, others might say better, but here goes
1. just because a very long distance between two galaxies which are sitting still in the space around them, just because this very long distance can increase at a rate that is more than one lightyear per year, does NOT mean that you could make a spaceship that could whiz past the Earth faster than c, or that something could ever CATCH UP TO A PHOTON AND PASS IT. those are physical impossibilities. they would involve short, local distances increasing faster than c. Change of short local distances is governed by special.
2. recession speeds are the rates of expansion of distances between two things each of which is at rest
3. no teacher, no book that pretends to teach, should ever present the speed of light as an absolute limit on the rate that all distances can change. It gives people the wrong idea and makes it more difficult for them to learn general relativity and cosmology later. If this has happened to someone they should try to get over the misconception. It's all one can do. Someone taught you a wrong thing, so you get over it and move on.
4. in the world we live in it is natural for distances between stationary things to change----by stationary I mean with respect to the microwave background or (equivalently) the expansion flow. Unless a distance is held constant by atomic forces or metal rod crystal lattice forces, or Earth bedrock, or the gravity forces of stable orbit, you EXPECT that distance to change. (the geometry of our world is dynamic, dynamic means it changes according to physical law)
5. in our world we have a criterion for being at rest, which is at rest with respect to the microwave background. if you are moving then there is a doppler hotspot ahead of you and a doppler coldspot behind you, and then you should COMPENSATE your observations.
the solar system is moving 380 km/s in a direction marked by the constellation Leo, which creats a doppler hotspot in the sea of microwave around us, a hotspot around constellation Leo and a coldspot in the opposite direction in the sky.
when we make observations that require our reference be at rest, we COMPENSATE for solar system motion and also we can compensate if necessary for the Earth's individual orbit motion which is not so fast, only 30 km/s.
that means the data is adjusted to make it be from the standpoint of a platform in space which is not moving with respect to the background----in other words not moving with respect to the universe, or the surrounding space.
for practical purposes, a few hundred km/s is not much, and individual galaxies are almost not moving at all, so for many purposes we just assume that two galaxies are each at rest with respect to background
then the distance between them will typically be expanding as I said earlier---it is what you expect to be happening between two stationary points----on average something like 1/140 of a percent every million years.
About Boltzmann brains. the actual idea of a Boltzmann brain is charming and I've thought about them some myself over the years---but very speculative of course.
However there is no TIME DILATION business that applies, of the sort you are talking
because recession speed does not cause it. special rel does not apply to recession speed.
it was a good try to think that time dilation could give more time for brains to pop into existence out of the seething vacuum, but it doesn't work (the time dilation idea doesn't work)
Hope this has helped.
