Universal cover of figure-8
Ok so apparently the universal cover of the figure-8 can be represented by the cayley graph of the free group on two generators, discussed in Hatcher and here http://en.wikipedia.org/wiki/Rose_%28topology%29" [Broken]
i can see why this is a universal cover of the figure-8. but I'm having trouble understanding why it cannot be something more simple.
for example, create a graph with one central vertex, and then four vertices surrounding it, and then connect each vertex to only the central vertex. (so you get a plus sign with vertices on the tips and one in the middle). isn't there a correct labeling on the edges of this graph to be a cover of the figure-8?
I'm not sure if this graph would be homeomorphic to the Cayley graph...ugh fractals.
Answers and Replies
Hurkyl
Staff Emeritus
What is the map from your plus sign to the figure 8?
As a sanity check, have you tried lifting some test paths on the figure 8 to your plus sign? (e.g. pick a half dozen or so paths that start at the middle of the figure 8 and proceed by randomly choosing one of the four directions and winding around until it returns to the middle and doing that a few times)
thanks..trying to lift some paths helped me see why what i was doing didn't make sense. the map i had in mind couldn't be a covering map bc there would be no evenly covered nbhd of the vertex of the figure-8. oops :-)
Related Threads on Universal cover of figure-8
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
