Universal Gravitation Practice
The discussion focuses on calculating the gravitational force exerted by Earth on an 80.0-kg astronaut at an altitude of 2.5 times Earth's radius. The formula used is FG = (Gm1m2) / r², where G is the gravitational constant, m1 is the mass of Earth, and m2 is the mass of the astronaut. The user initially calculated FG as 2.00x10^12 N but later confirmed the correct force is 64 N. Clarification on the variables indicates that altitude refers to the height above Earth's surface, while r represents the distance from Earth's center. Understanding these definitions is crucial for accurate gravitational force calculations.
chroncile
What force does Earth exert on a 80.0-kg astronaut at an altitude equivalent to 2.5 times Earth's radius?
FG = (Gm1m2) / r2
Radius of Earth: 6370 km
Mass of Earth: 5.97x1024 kg
FG = (Gm1m2) / r2
FG = (G x MEarth x 80 kg) / (6370 x 2.5)2
FG = 2.00x1012 N
The correct answer is 64 N
What is G? And altitude means "above the surface of the Earth" and r means the distance from the centre of Earth.
ehild
