Where Should the Certificate Be Awarded on a Space Tour from Earth to Moon?
The discussion centers on determining the optimal point to award a certificate during a space tour from Earth to the Moon, specifically at the location where gravitational forces from both celestial bodies are equal. Participants express confusion over the calculations needed to find this point, particularly regarding the gravitational force equations. It is clarified that the forces acting on the spaceship from Earth and the Moon can be equated to find the balance point, which involves understanding the distances from each body to the ship. The conversation emphasizes that the gravitational force magnitudes must be equal for the net force to be zero, leading to the conclusion that the certificate should be awarded at this equilibrium point. Overall, the focus is on the physics of gravitational forces in space travel.
ML1
Transplanertay tours promises tour participants a certificate to commemorate their passage from the stronger influence of Earth's graviational pull to the stronger pull of the Moon at the point where the two forces on your spaceship are equal. Where on the trip should you award the certificate?
F_G = G (m_1)(m_2)/ (r^2)
We know that F will equal zero right...? I'm confused how to go about it. I know I'm solving for r but if F= 0 i can't solve for anything.
Yes. :approve: [Edit: Well, at least the component of the resulting force that is parallel to the line intersecting the Earth and the Moon will be zero. If the ship is not on that line, there will be non-zero component of the net force pushing it toward that line.]
There are two rs involved. There is the distance from the center of the Earth to the ship rearth_ship, and the distance from the ship to the center of the Moon rship_moon.
If the ship happens to be on a line intersecting the Earth and Moon, These two distances are related by the distance from the center of the Earth to the center of the Moon dearth_moon.
dearth_moon = rearth_ship + rship_moon *​
*(Again though, the above equation is a special case where the ship is on a straight line between the Earth and the Moon. If you keep things in terms of both rearth_ship and rship_moon, you don't need to use the above equation, and your answer will apply more generally.)
In general, there are two forces on the ship we are concerned with. There is the force of gravity from the Earth and there is the force of gravity from the Moon. It is the sum of these equal and opposite force magnitudes that equals zero -- not just anyone particular magnitude.
[Edit: in other words, set the magnitude of the Earth's gravitational force on the ship equal to the Moon's gravitational force magnitude on the ship, and simplify.]
Like this...?
F (M_e)(M_s) / (R_es)^2 = F (M_s)(M_m) / (R_ms)^2 ?
:confused:
es - Earth/ship
ms - moon shop
ML1 said:
Like this...?
:confused:
es - Earth/ship
ms - moon shop
Yes, except remove the "F" from both sides of the equation.
You can also simply further too. Notice that M_s cancels out.
